The Baron
| posted on 23/2/08 at 01:28 PM |
Transmission Tunnel
I've just cocked up my transmission cover (the top part) again. It could be salvageable if----- I could get hold of some 90 degree trim ideally
aluminium angle. I have looked in B&Q but there ally angle would fail the 2mm radius as it has a sharp external corner, does any one:-
1. know here I could get some ally angle with a 2mm radius,
2. Or know where I could get some ‘other’ 90 degree trim to do the same job.
Cheers in advance.
B
worX
| posted on 23/2/08 at 01:32 PM |
You want some "Hockey Stick" Trim, I think some other places call it "J" Trim aswell.
It's available form a few of the kit manufacturers, but not sure if the conventional shops sell it.
HTH
ETA - Photo, here's a shot of mine (powder coated black on the tran tunnel and plain ali on the outside)
  rubber floor and new tran tunn
[Edited on 23/2/08 by worX]
| posted on 23/2/08 at 01:33 PM |
You can get 90 degree rubber trim.... SVA very friendly...
rpm
| posted on 23/2/08 at 01:37 PM |
I used b+q type trim but arrissed off the corner with a grinder and finished it with wet and dry paper it passed sva no problem
The Baron
| posted on 23/2/08 at 01:40 PM |
worX
Thats the stuff i want, give me, give me, give me......
where can i get some, please someone heeeeeeelp!!!!!!
worX
| posted on 23/2/08 at 02:17 PM |
Mine is from MAC#1, but it can also be bought from MK, Aries Motorsport and a few other manufacturers...
quote: Originally posted by The Baron
worX
RazMan
| posted on 23/2/08 at 05:49 PM |
I used anodized step edging from B&Q which Mr SVA loved.
Raz
DarrenW
| posted on 23/2/08 at 09:49 PM |
I took the hockey trim off mine and commisioned a full pad to be made. Much better solution - all together more tailored. Only cost £55 with some
pockets.
mackei23b
| posted on 23/2/08 at 09:54 PM |
Try Woolies Trim
Ian
