MK Charlie
| posted on 3/3/08 at 05:46 PM |
Lotus Elise seats
Does anyone know if seats and subframes from a Series 1 Lotus Elise will fit an MK Indy?
Charlie
hector
| posted on 3/3/08 at 06:06 PM |
I have elise seats in my Viento
Would you like the dims of the runners/subframe?
cheers Colin
chrsgrain
| posted on 3/3/08 at 06:20 PM |
Probably not hugely helpful, but they fit in a Dax with a bit of fiddling... if you need pictures / dimensions let me know.
Chris
MK Charlie
| posted on 3/3/08 at 06:36 PM |
Could I have the dimensions on the width of the subframes, and the widest part of the seat please?
Cheers guys
chrsgrain
| posted on 3/3/08 at 06:47 PM |
Ah - here is where it gets interesting - the subframe lies outside the bottom of the seats - and makes them quite wide - I altered mine so the
subframes went under the seat (but this did raise them up a bit) - that's what I meant about fiddling... will measure later!
Chris
chrsgrain
| posted on 3/3/08 at 07:20 PM |
Right, all measurements in mm;
Front, edge to edge - 410
Back of seat cushion / bottom of back support - 420
Widest part (where the back flares) - 470
Don't have the original subframes....
Chris
hector
| posted on 3/3/08 at 07:45 PM |
Mine have the original subframes and they measure 445mm wide by 430 long, so as long as your cockpit is wider than 445mm
then no reason why they shouldnt fit.
Thhe widest part (470mm) is at shoulder height
Hope this helps
cheers colin
