ghvh
| posted on 6/11/03 at 10:43 AM |
Mini Heater
Has any one fitted a mini heater?
It looks to me as if it would fit centraly, half way through the scuttle leaving the ducts facing in to the car and the radiator and fan under the
bonet.
Does any one know if there is any sva problem with this?
craig1410
| posted on 6/11/03 at 01:19 PM |
I'm not sure but I'd guess that blowing air from the engine bay into the cockpit (even an open top cockpit) wouldn't be a good idea.
If you could duct the intake so that it draws air in from the scuttle or bonnet and then ensure that the engine bay and cockpit are sealed from each
other then it should be okay. I'm still waiting on my SVA manual arriving so I can't be certain...
Craig.
timf
| posted on 6/11/03 at 02:34 PM |
wasn't the mini heater setup the way hicost had it.
resulting in
http://www.locostbuilders.co.uk/viewthread.php?tid=7431
blueshift
| posted on 6/11/03 at 09:42 PM |
as far as I know most cars take air from the engine bay to blow into the cockpit / cabin. quite normal.
| posted on 6/11/03 at 11:53 PM |
often the heater blower is behind the bulkhead, sucking from the bottom of the windscreen, so its not really from the engine bay itself. On the sierra
it was quite well seperated by the rubber stuff.
| posted on 7/11/03 at 10:39 AM |
Early Mini heaters recirculated the air in the car, later ones had a plastic pipe under the wing which ducted air from the front grill before the
engine. If you could duct air from behind the radiator you would be halfway to solving the problem.
yours, Pete.
stephen_gusterson
| posted on 7/11/03 at 10:45 AM |
mini heaters were mounted in minis the same way hicost did.
If the hose blows off, as it did for James, then its gonna dump on you. But so will any heater thats mounted in the car by your feet.
Use good tight clips, new hose, and mount deflector plates so that water cant blast your feet should a problem arise.
I have a mini heater, and to mount 'thro scuttle' would be nuts. the water bit is right at the front by the dash, so thats no help, and
the fan bit would be in the bonnet, drawing in fumes.
The heater is compact, but a little 'deep' behind dash. I tilted mine a little to reduce the depth.
Look at a sierra heater and a mini one looks a much better proposition!
atb
steve
andyps
| posted on 7/11/03 at 02:12 PM |
Steve is right about the piping - many cars have hoses carrying hot water inside the car - just take a look at where the hoses go from your engine and
they will almost certainly pass through the bulkhead. This is certainly the case on my Rover 800 - there is always the possibility of what happened to
hicost in most cars. It just depends how close the pipes are to your body as to the damage which could be caused.
The good thing in a mini is that if the hoses need replacing at least you can get at both ends of them easily!
Ben_Copeland
| posted on 7/11/03 at 09:56 PM |
I used to have a mini heater in, but decided to remove it after Hicost's accident. Also i didn't like the look of it.
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
stephen_gusterson
| posted on 7/11/03 at 11:45 PM |
depends how you mount it. mines hidden behind a nice walnut dash and the legent plate looks good over that, rather than floating in mid air ala
mini
atb
steve
Ben_Copeland
| posted on 8/11/03 at 12:31 AM |
Didn't like the look of it... whatever i did with it. My opinion.
You like it, thats your opinion.
Plus its unnecessary weight in my car
Ben
Roadster
paulbeyer
| posted on 8/11/03 at 08:16 PM |
I was in the car with Hicost when he boiled his feet and that decided it for me. My neighbour runs his own business supplying motorbike clothing and
safety gear and he sells 12v heated clothing. I posted on here a while back and got zero interest. Oh well.....
7 out of 10 people suffer with hemorrhoids. Does that mean the other 3 enjoy them?
Ben_Copeland
| posted on 8/11/03 at 08:34 PM |
Think most people would sooner just wrap up warm, cheaply.
Think the main reason why people have heaters is to demist their windscreens!
Ben
Roadster
paulbeyer
| posted on 11/11/03 at 08:54 AM |
You could drape your 12v powered undercrackers over the screen.
Not sure if it would get passed the SVA Gestapo though.
James
| posted on 26/11/03 at 05:13 PM |
Lol!
I actually read "undercrackers" as meaning his plums the first time I read it!
James
Ben_Copeland
| posted on 26/11/03 at 05:35 PM |
Right.........
*Must remember not to go near James at the next meet*
Ben
Roadster
