Bluemoon
| posted on 23/3/08 at 07:21 PM |
Sierra clocks photos
Hi All,
Looking for inspiration on using the sierra clocks and making them look o.k. Can't afford flashy clocks, so anyone got some photos of using
standard/modified sierra clocks..
Dan
jacko
| posted on 23/3/08 at 07:29 PM |
I used the sierra clocks there is 3 photos in my archives
If i new how to post them on here i would
Jacko
big_wasa
| posted on 23/3/08 at 07:30 PM |
google robin hood dash ect
jollygreengiant
| posted on 23/3/08 at 07:49 PM |
Not Sierra but Granada. Very similar. (same pod I believe).
  Dash update
and
  dash fitted with surround
Basically I removed the perspex front, cut it down almost flush (room for needles to move plus a bit). then used the mounting in reverse to mount onto
back of dash and fit new perspex and alli surround to front.
RichardK
| posted on 23/3/08 at 09:14 PM |
My effort
Loads more in my gallery, link below.
Rich
Gallery updated 11/01/2011
C10CoryM
| posted on 23/3/08 at 11:31 PM |
Most instrument clusters like that use simple printed circuit boards. Meaning if you can solder, you can cut the gauges out and move them around as
you like. Connect the wires you cut with some copper wire. Takes a little thinking, but you can end up with a nice setup for nothing. Even nicer if
you get a decal made up for the backgrounds.
"Our watchword evermore shall be: The Maple Leaf Forever!"
dr-fastlane
| posted on 24/3/08 at 09:04 AM |
More pictures in my photo archive
I have not failed once. I have successfully found ways that will not work!
https://www.motor-forum.nl/threads/hardtail-dragstyle-project.343482/
Chippy
| posted on 24/3/08 at 05:47 PM |
Not as posh as some, but suites me. Ray
Bluemoon
| posted on 26/3/08 at 08:45 AM |
Thanks all..
Dan
