jimgiblett
posted on 25/3/08 at 10:58 AM |
Seatbelt / harness mounts thread spec
Anyone know the thread spec on seatbelt / harness mounts. Is it 7/16 fine?
My rollbar is going for powder coating and I will need to retap the harness mounts and thus need to buy the correct relevant size.
Thanks in advance
- Jim
mike smith1
posted on 25/3/08 at 11:04 AM |
It's 7/16 UNF
Mike
[Edited on 25/3/08 by mike smith1]
bigrich
posted on 25/3/08 at 11:07 AM |
Yep 7/16 unf
jimgiblett
posted on 25/3/08 at 11:20 AM |
Thanks guys. I'll go buy a tap.
- Jim
posted on 25/3/08 at 11:23 AM |
It is very likely to be 7/16 UNF
but.......
some harnesses are now M8 12.9
Guess how I know this
It's normally quite easy to tell the difference between the two though as 7/16 UNF is significantly bigger than M8...
posted on 26/3/08 at 08:00 AM |
7/16 UNF (just a smidge over 11 mm)
now 8 mm?!?!?! that is 52 % of area of 7/16, no wonder the specify a stronger bolt!!!
Is opening out the harness holes to 12 mm and using 12 mm bolts a terrible suggestion?
jimgiblett
posted on 26/3/08 at 09:13 PM |
Yep 7/16th but the local factors want £20+VAT for the tap so I might just drop it off at the machine shop after it has been powdercoated to clean the
threads out.
- Jim
iank
posted on 26/3/08 at 09:55 PM |
but.......
How would that play at SVA? It specifies 11mm 7/16 or larger 8.8 grade as the minimum adequate spec. Even upping the grade to 12.9 isn't
likely to compensate for that great a reduction in diameter [he says without running off and doing the maths ]
Anonymous
vinnievector
posted on 27/3/08 at 07:27 PM |
Hi
Some quick info on UNF 7/16 according to my trusted Zeus book.
if you want to tap a new hole you require a 9.9 mm drill if you , want to drill a clearance hole then you will need a 11.2 mm hope this helps .
