foes
| posted on 3/4/08 at 06:54 AM |
Kart steering wheel...?
Is anybody using go-kart steering wheel, something like this maybe...?
wheel
cheers
stevec
| posted on 3/4/08 at 07:20 AM |
I think they may be a little weak around the middle for a car, probably depends on the quality.
Steve.
procomp
| posted on 3/4/08 at 07:46 AM |
Hi as said above they just dont have enough strength for the weight of a car. Trust me it's been tried. Although i have no idea if it will
actually pass an sva or not. It certainly did not last long on a race car.
Cheers Matt
nitram38
| posted on 3/4/08 at 09:59 AM |
I'm going to use one on the MotaLeira.
Seems pretty strong to me:
gingerprince
| posted on 3/4/08 at 02:04 PM |
My car has one and I've had no problems in the 2 years I've had it so far, even with a quick rack...
  Dashboard Finished
No sign of any stress, and of course it's all fastened together with 8.8 bolts which are taking the sheer load.
ko_racer
| posted on 3/4/08 at 02:12 PM |
I can see no issues using a kart steering wheel. The karts I've raced have been much harder on the wheel than either of my race cars.
Even in some of the big off's I've had the worst I've done to the wheel was bend it slightly.
Karters use the wheel to brace themselves under braking, in a car your harness holds you in place.
foes
| posted on 3/4/08 at 02:40 PM |
thanks for the replies lads...
nitram, what make is yours and where from, looks good..?
Also are all kart wheels the same size? sva not a problem as it will be for track use.
cheers
ko_racer
| posted on 3/4/08 at 02:53 PM |
try
Karting Direct
Zoom Karts
Dartford Karting
Spellfame
They are roughly all the same size.
[Edited on 3/4/08 by ko_racer]
nitram38
| posted on 4/4/08 at 04:45 AM |
cheers
Just an ebay find, don't know anymore I am afraid.
Fred W B
| posted on 4/4/08 at 06:05 AM |
Nitrams looks like the one I've got - called a "Zee1" from davidson karting
Fred W B
