Author: Subject: Bolts (yet again!) on harnesses
madmandegge
posted on 18/4/08 at 11:06 AM Reply With Quote
Have a set of Willans harnesses which I want to fit, but am unsure whats going on with the bolts at the top of the harness. The lower mounts have no bolts, so am just going to use normal 8.8 seat belt bolts.
Any ideas whats going on with these?
It almost looks like they're welded? Or am I way off?
TIA
mookaloid
posted on 18/4/08 at 11:49 AM Reply With Quote
Can't quite tell from the piccys but if they have been welded or subjected to heat they could have been weakened and should be replaced.
This is a safety thing so don't take any chances.
mark
eznfrank
posted on 18/4/08 at 12:15 PM Reply With Quote
Looks like they've been welded on so that the belts can rotate but still remain secure ie. not gripping the belt mounts. I'd just cut them out and replace with proper seat belt botls with the collar on.
madmandegge
posted on 18/4/08 at 12:30 PM Reply With Quote
Sounds like a plan, I'll have a go at getting them off.
This has probably been asked before, but where's the best place to buy the collars from? I thought I could get some bolts from a scrap yard, but I suppose those might've been weaked on impact, so new ones are probably the best idea.
Anywhere either online or in the West Midlands area? Thanks again
eznfrank
posted on 18/4/08 at 03:28 PM Reply With Quote
Never bought any myself as they came with my harnesses but try people like Demon Tweaks or some of the rally suppliers etc.
mad4x4
posted on 18/4/08 at 05:08 PM Reply With Quote
Top mount bolts need to be stamped 8.8 for sure even if it is the "eye" type for a clip in harness - I know min failed as they didnlt have 8.8 on them & I got mine with my harnesses
Damon tweaks do harness eyes.
As said above welded bolts are a no no my inspector even queried the mounts a bit
Scot's do it better in Kilts.
madmandegge
posted on 18/4/08 at 07:12 PM Reply With Quote
Thanks guys, I'll have a look at demon tweeks.
The bolts came off eventually after a lot of furious hack-sawing.
I don't have to pass SVA with them, but obviously I'm more interested in safety than the cost
Still open to ideas as to where to buy! Cheers
[Edited on 18/4/08 by madmandegge]
madmandegge
posted on 18/4/08 at 07:24 PM Reply With Quote
I may be blind (quite likely) but I can't see anything on demon tweeks!
I'll just be off to the "Wanted" subforum
Metcalfe
posted on 2/6/08 at 08:08 PM Reply With Quote
so do i not need bolts on my harness mounting points?
i've just aquired a set of securion 4 point harnesses for my build, but they come with 4 clip on type ends..
Will it pass an sva with this arrangement?
