jabbahutt
posted on 12/5/08 at 10:34 AM |
column top shroud gap
Morning all
Finally got the steering wheel boss fitted and the upper and lower column shroud. I'm left wirth a large gap between the rear of the cover and
the dash.
I vaguely remeber seeing a post on it many moons ago when I first started building but cannot find it.
Has anyone else found this problem and ow have they got round it, explainations/photos much appreciated.
Nigel
posted on 12/5/08 at 10:47 AM |
Have a look through Hellfire's website for ideas. They made up cover out of some ally sheet covered in vinyl to match the dashboard and secured
the cover with screws to the Sierra top shroud.
I follwed the same method using black vinyl as per my dash and securd with black self tappers. It's a pretty neat solution IMHO.
indykid
posted on 12/5/08 at 05:24 PM |
i've sika'd a piece of aluminium shaped to fit the dash and the shroud on top. i then sprayed the whole top section satin black and it
matches the bottom nicely.
if it's less than about 8 mm, you can loosen the pinch bolt on the column mount and slide it up and down the black collapsible section.
tom
