The Doc
posted on 23/6/08 at 11:40 AM |
Dellorto Linkage
Has anyone used the carb to manifold mounting studs to secure a twin carb linkage plate. I notice most units are mounted on top of one carb.
Any reason why the inboard studs should'nt serve this purpose. It would suit my application to use an angled piece of metal attached in this
way.
Any thoughts?
Mike
posted on 23/6/08 at 11:55 AM |
Not really a good idea the carbs should be flexibly mounted to the manifold via rubber O rings and rubber washers.
[Edited on 23/6/08 by britishtrident]
Paul TigerB6
posted on 23/6/08 at 12:04 PM |
Tiger do something similar to what you suggest but as BT says above you need to make sure you retain the flexibility in the carb mounting
posted on 23/6/08 at 12:13 PM |
Put some longer studs in and trap it between two nuts?
