orbital
| posted on 4/7/08 at 11:43 PM |
Will This Switch Pass SVA?
Hi All,
I'm still faffing about trying to find some switches for my new dash. I was going to get some Savage ones, but the £15 per switch put me off
somewhat!! What do people think of these ones (is anyone using them?) and do you think they'll pass SVA ok?
Dave
RK
| posted on 5/7/08 at 03:13 AM |
Why wouldn't it? I don't see his little orb getting any sharp edges from that.
RazMan
| posted on 5/7/08 at 06:55 AM |
Nice little switch that - should be fine
Raz
DRC INDY 7
| posted on 5/7/08 at 09:10 AM |
I am useing one of those for my electric fan
Puddle Dodgers Club
orbital
| posted on 5/7/08 at 10:07 AM |
No I couldn't see any reason why it shouldn't, but I just thought I'd ask in case someone knew different
DRC INDY 7
Whats the switch like? Do you think it'll last ok?
Dave
RazMan
| posted on 5/7/08 at 10:41 AM |
It will need to be rated at >10A for a fan - worth checking or it will fail quickly
Raz
iank
| posted on 5/7/08 at 10:50 AM |
Doesn't look to be waterproof. Whether that matters or not depends on whether it'll get wet where you mount it when it, inevitably, rains
on you.
If you've got the datasheet IP65, IP66, IP67 or IP68 will tell you that's it's waterproof.
Anonymous
orbital
| posted on 5/7/08 at 12:32 PM |
They are rated at 16A @ 12volts.
would that get round having to use relays? The thought of re-locating my column switches is bad enough without having to mess about with relays too
I can't find a datasheet on them, but I don't intend to take the car out even if there's a hint of rain
Dave
[Edited on 123131p://3215 by orbital]
[Edited on 123131p://3315 by orbital]
RazMan
| posted on 5/7/08 at 01:54 PM |
Yep, you can get away with that - 2 x 55W headlamps will draw less than 10A
Raz
orbital
| posted on 5/7/08 at 02:05 PM |
Cheers Raz
MakeEverything
| posted on 9/8/08 at 10:21 AM |
Unfortunately, the best laid plans an' all that.....
[Edited on 9/8/08 by MakeEverything]
Kindest Regards,
Richard.
| posted on 11/8/08 at 10:23 AM |
hmmm, I am not so sure. I'd have to look at the manual but there is a 4 mm (?)gauge that would casue the top edge of the rocker to fail.
