Author: Subject: seat mountings
ian.lucas
posted on 28/7/08 at 01:13 PM Reply With Quote
seat mountings
can you mount the seats directly through the floor, I've heard you need 100mm long x 100mm wide x 4mm thick plates, the 2 front ones mounted on the inside of the car an the rear on the under side of the car ??? can anyone confirm this ??
nib1980
posted on 28/7/08 at 01:17 PM Reply With Quote
Mine were bolted through the floor using two 4mm strips acroos the front and rear bolts to spread the load, using 8.8 bolts, no concerns from my SVA for me
tjoh84
posted on 28/7/08 at 01:18 PM Reply With Quote
my locost seat pads are bolted straight in to floor
Howlor
posted on 28/7/08 at 01:25 PM Reply With Quote
Mine were bolted through the floor. Backs through the steel crossmembers but fronts just through the alu plate. I put some nice large washers on to spread the load and they were absolutely fine for SVA.
worX
posted on 28/7/08 at 01:26 PM Reply With Quote
Yes you can.
Just used large washers and it's fine.
Dangle_kt
posted on 28/7/08 at 02:05 PM Reply With Quote
Whats your floor made from? Steel or Alu
wicket
posted on 28/7/08 at 02:41 PM Reply With Quote
Cobra seats bolted to the welded in steel floor using fixings supplied with seats, large diameter washers on the underside, no problems at SVA.
adithorp
posted on 28/7/08 at 04:10 PM Reply With Quote
Where the floor is non-metallic there's an SVA requirement for spreader plates.
Otherwise they just have to be "...secured firmly to the chassis or other obvious load bearing part...". That must include the (ally) floor panels as thats all mine are fixed to. I have large 60mm ally washers on mine.
adrian
A1
posted on 21/8/08 at 09:19 PM Reply With Quote
ive just finished making some unadjustable seat brackets and putting the bolts through the floor and them... i think its 3 mm steel i used...seem pretty damn strong
Mix
posted on 22/8/08 at 03:32 PM Reply With Quote
Hi
If you think about it the seats in a typical seven, (or most cars for that matter), take very little load, the high loading is taken by the harness. The exception being a rear end shunt, but then most Locost seats are fairly close to the rear bulkhead. Providing the flooring is sufficient then M8s and penny washers should be fine.
Don't you think it strange that you are proposing making seat mounts stronger than those required for the harness'?
Mick
