Kriss
| posted on 29/7/08 at 05:02 PM |
What size wheel
Decided I defo want to move to a smaller wheel asap.
Have a normal Sierra rack on my Indy. Would a 270mm be to hard to use? really fancy the MOMO type 27
Chris
COREdevelopments
| posted on 29/7/08 at 06:37 PM |
i have a momo think its 280, everyone says that 280 is too small. and tbh they are right. i think a 300 would be best comprimise. my momo 280 sure
does look good though.
rob
tjoh84
| posted on 29/7/08 at 08:39 PM |
i got a 280 and think its fine
worX
| posted on 29/7/08 at 08:59 PM |
As said on your last wheel post, that size is fine, but you need a quickrack...
Kriss
| posted on 29/7/08 at 09:58 PM |
been measuring and messing about and think i am going to settle on a 290mm gaining 40mm of room
how easy is a quick rack to instal and remove old item? any links at all guys?
worX
| posted on 29/7/08 at 10:09 PM |
A quickrack (if made for you to the same size as your existing one will take you between 20mins and and hour to do depending on your competency.
It is a very simple job to do mate, and if you need any pointers just before it (like advice or to check you've got the correct tools) then a
simple post on here will sort that out.
Kriss
| posted on 30/7/08 at 11:48 AM |
Ah ha cheers for that steve. Was just wondering as its one fo the first items to be fitted in a build that was all.
Any links to places that sell? I take it, its just the rack set (box with reworked gearing) and NO column, steering rods etc
Kriss
| posted on 30/7/08 at 01:05 PM |
bah this is driving me mad trying to find a wheel.
settled on the Sparco 285 SN. Its an undrilled wheel so perfect i thought for my application.
then rung demon tweeks to buy it who said that my 6 hole boss would be too big?
surely the wheel would overlap three of the holes on the boss though? I know it would mean the boss is slightyl expossed, but what else can i do to
get a smaller wheel. the quick release kit is 3 holes mounting to a spacer which has 6 holes which mount to the wheel. no one makes a spacer which is
thee holes and then three holes.
spose i would space with a bunch of washers?
opinions?
