Author: Subject: CSM release agent
Avoneer
posted on 23/12/03 at 01:05 AM Reply With Quote
CSM release agent
Anyone know of anything to use as a release agent when you haven't got any wax or other propper stuff?
Apart from cling film.
I will be laying onto MDF.
Pat...
Alan B
posted on 23/12/03 at 02:30 AM Reply With Quote
Well, proper release agent is PVA.....so failing having some perhaps you could dilute some PVA wood glue...
DISCLAIMER..
Don't blame me if it doesn't work..
stephen_gusterson
posted on 23/12/03 at 09:40 AM Reply With Quote
Originally I thought that
however the pva glue I have and the pva liquid for grp use appear to be totally different.
like - one is a sticky glue and the other is a very volatile evaporative substance that deposits a 'cling film' like substance.
PVA diluted is used to seal wood - and its absorbed quite well. make sure the surface is really well sealed if you attempt using dilute pva glue.
the word glue puts me off
atb
steve
[Edited on 23/12/03 by stephen_gusterson]
Simon
posted on 23/12/03 at 12:50 PM Reply With Quote
Pat,
I used an mix of engine oil and vaseline (engine oil to thin the grease) - very sparingly (basically so it stains the wood), on all moulds I made.
They were usually a combo of MDF, ally sheet and plaster of paris.
Like Alan says, try a bit for yourself, before blaming me
Simon
type 907
posted on 23/12/03 at 01:03 PM Reply With Quote
Hi there, I am type 907's son home for christmas from uni, Before uni I was a prototype modelmaker for seven years and have done a bit of molding in my time.
Iam now studying car design, (its a hard life)
As far as release agents are concerned if you want to use something that you might have at home, try a light smearing of vasaline or a build up of bee's wax furniture polish which you can buff to a great finish.
saying that, test the two ideas first and see which works best for you.
Hope this has been some help.
Gaz
Too much is just enough
Avoneer
posted on 23/12/03 at 04:18 PM Reply With Quote
I like the sound of the oil and vaseline one.
Watch this space.....
Jasper
posted on 23/12/03 at 04:44 PM Reply With Quote
Hey - I like the sound of oil and vaseline mixed too
paulbeyer
posted on 23/12/03 at 11:28 PM Reply With Quote
Jasper you're not being deviant with your teddy bears are you?
7 out of 10 people suffer with hemorrhoids. Does that mean the other 3 enjoy them?
