big_wasa
| posted on 7/9/08 at 09:20 AM |
A bit more progress
Work is getting busier but Ive still got a few hours in on the 7
[Edited on 7/9/08 by big_wasa]
gavin174
| posted on 7/9/08 at 09:25 AM |
only my oppinion (spelt wrong) but i wouldnt panel the car up until you have the brake lines and wiring in position as it can be quite restricting
(and easily damaged)
looks good thou
natehall
| posted on 7/9/08 at 09:29 AM |
Im so tempted to build one of these its unreal, i just dont have the workshop/garage space to do it
If i write my track car off - ill do it with that as the donor
If it aint broke, uprate it
if it is broke, uprate it
http://www.modders-uk.co.uk
nib1980
looks good thou
Good point but i think it's not fixed yet, hence the cleco fasteners. (But i may be wrong as i usually am!)
big_wasa
| posted on 7/9/08 at 09:37 AM |
yep its not fixed yet.
The plan is to dry build then strip paint and rebuild it like a kit.
StevieB
| posted on 7/9/08 at 11:08 AM |
That's what I plan to do with my next kit - it'll make for a better build as you can weld on little tabs and brackets rather than use ali
or steel angle and rivets. It'll give a better end result (if a little more time consuming).
I take it you've primed the cahssis to stop it rusting in the meantime?
Build looks good too!
big_wasa
| posted on 7/9/08 at 01:26 PM |
yep did that just before winter 2 years back.
Like you say I have found a few extra bits to weld on.
