mr henderson
posted on 25/9/08 at 02:30 PM |
Movable pedal box, anyone seen any nice versions?
For an upcoming project, the best way to deal with different driver heights would be to move the pedal box backwards and forwards, rather than the
seat.
I'm wondering if anybody would like to comment on this, whether they have seen any good systems, or how they think it might best be achieved.
It's not been decided yet whether the pedals should be top or floor mounted, but I'm thinking top.
The clutch will be hydraulic, and the brakes almost certainly adjustable bias bar. Throttle will be cable.
The actual adjustment procedure- anything that can be done in a few minutes, doesn't matter whether it's from the driver's seat or
it's a bonnet up and spanners out job
Thanks in anticipation
John
l0rd
posted on 25/9/08 at 02:36 PM |
Wouldn't this be failure on the SVA test?
Anyway, i have many ideas on it You would need to spend quite some money on getting extra braided pipe lines for all this.
mr henderson
posted on 25/9/08 at 02:54 PM |
I don't know. I don't remember seeing anything specific about it. If the pedal box was mounted by bolts then I can't see why there
shouldn't be different holes it could bolt into.
Might be worth it, though. Would only be 3 hoses and some fittings
Triton
posted on 25/9/08 at 03:03 PM |
Forgot the name of the car but it was a mid engined sevenesque thing using vauvhall motor...made in Blackpool maybe?
Well whatever it was called it had a trick pedal box that was so simple you could put a tail on it and call it a weasel..
www.tritonraceseats.com
www.hairyhedgehog.com
Richard Quinn
posted on 25/9/08 at 03:12 PM |
Probably not SVA friendly in its current form, but something along the lines of...
[img][/img]
Bob C
posted on 25/9/08 at 03:33 PM |
I think the old marcos "mantula" (or sommat) had a pedal box that screwed back & forth using a big wheel on a leadscrew - I'm
going back to the 70s here
aka Keith
posted on 25/9/08 at 03:42 PM |
IIRC, most of the Marcos's (plural) had an adjustable pedal box and a fixed seat, even up to the latest generations. I looked at buying one a
couple of years ago.
Mix
posted on 25/9/08 at 04:06 PM |
Hi
There was a rear/mid engined sevenesque car with removable roof panels which stowed behind the seats, I think. Definitely had an adjustable pedal box,
went out of buisiness in the 90s I think. Please someone come back with the name as this will bother me now
Regards Mick
mr henderson
posted on 25/9/08 at 04:12 PM |
That will be the Vauxhall based.........., Gawd, I've fogotten too. See it in my head, can't get the name
John
Mix
posted on 25/9/08 at 04:41 PM |
Hi
Found it
CC Cyclone..............happy now![](/images//smilies/smile.gif)
Regards Mick
mr henderson
posted on 25/9/08 at 05:09 PM |
quote: Originally posted by Mix
Hi
Found it
Regards Mick
There you go, I though it started with a C, but I got stuck on Calibra (a frequent donor for the Cyclone) and couldn't get past it
John
blakep82
posted on 25/9/08 at 07:02 PM |
as long as the brake (and hydraulic clutch) pipes are flexi, and its securely bolted in, i don't see a problem really
________________________
robinj66
posted on 25/9/08 at 09:03 PM |
Gardner douglas supply an adjustable pedal box for their Cobra replicas.
I don't know much more than that, I'm afraid![](/images//smilies/tongue.gif)
