designer
| posted on 1/10/08 at 08:15 AM |
Speedo
I know that the speedo is checked in the SVA, but are there any rules on how information for the reading is gathered?
This:
http://www.instructables.com/id/NonTraditional-Speedometer-for-Used--Homebuilt-Ca/
could be an option. But it would be impossible to check on SVA.
Mr Whippy
| posted on 1/10/08 at 08:30 AM |
soooo you like saying fit a radar gun to your car and use it as a speedo? but that will pick up any oncoming traffic and you'll then
you'll be doing 140mph!
if you point it at the ground what’s the beam reflecting off? cats eye's?!
for about £12 you can buy a push bike digital speedo that stores total miles and uses a magnet and reed switch on the front wheel as I have on my push
bike
[Edited on 1/10/08 by Mr Whippy]
ravingfool
| posted on 1/10/08 at 10:34 AM |
No you point the beam down so there would be no interference from traffic etc.
I thought you were a physics bod? no it would just be reflecting off of the ground, you know, in the same way light does so that we can see the
ground!
bike
To be honest, even a bike speedo has got to be preferable to a radar based custom speedo. These aren't small units, but you'd want to
mount it completely under the car which would be difficult, and realistically you're either going to mount it somewhere it's going to get
hit occasionally and eventually damaged, or it'll get killed by moisture.
It sounds like a very expensive and short lasting toy. Don't know about the legality for SVA though.
pewe
^^^ What Mr. Whippy said about a bike speedo as you can calibrate it pretty accurately - must be no more than 10% over/under the correct speed.
Also I think it needs to be visible at night - probably there's a bike speedo with illumination as night-time off-roading is becoming popular
amongst mountain-bikers (but only those with a death-wish!) or I'm sure you could rig up an LED or similar without too much trouble.
Cheers, Pewe.
Rosco
| posted on 1/10/08 at 11:00 AM |
I guess the other consideration is the Mr SVA needs to be able to test it against a calibrated standard, which I presume they do on a rolling road, so
you're limited to measuring wheel speed rather than road speed.
| posted on 1/10/08 at 12:06 PM |
ground!
You are gonna have to explain how this works.
Radar sends a beam of something and measures time for reflection to come back. Doing this repeatedly on a moving object will result in the time for
reflection changing. The difference in time can then be used to determine the relative speed.
So unless the car is changing the distance between itself and the ground, like taking off in an air-plane-like fashion , I fail to see how it is
gonna work realiably, if at all.
The radar needs to point at some stationary or very slow moving object in the distance horizontally e.g. tree, large house, stationary traffic, giant
tortoise, pedestrian, guide dog etc.
Mr Whippy
| posted on 1/10/08 at 12:12 PM |
really using a radar gun as a speedo is quite a crazy idea and would never pass an SVA test, full points though to the sales guy for even comming up
with such a sales pitch
ravingfool
| posted on 1/10/08 at 01:52 PM |
OK, what you say about repeated measurements to establish a speed for a moving object is correct.
However you can also measure the speed of an object by firing just one pulse at it, or from it and measuring the returned signal, because of the
doppler effect, which is what causes the 'red shift' experienced looking at distant galaxies. With the distant galaxies because they are
moving away from us you can imagine that the light waves get stretched, which equates to a lowering in their frequency and a shift towards the red end
of the spectrum.
The same effect can be used in any other kind of wave to measure the speed of objects. If the radar is set up to look slightly ahead of it's
position the ground will in effect be moving towards the radar gun. The reflected waves will effectively be squashed and there will be a measurable
increase in frequency. The difference in emitted and received frequencies will allow calculation of speed.
Whether it is the radar gun or the object being targeted that moves is irrelevant as the same effect is caused.
I hope that helps, also, consider cars driving towards and then away from you. As they rush towards you the sound increases in pitch because the
frequency increases as the waves are being compressed. When a car passes you and then drives away the pitch of the sound decreases as the frequency
of the waves decreases with the waves being more spread out as the distance between you and car increases. (although it is not the distance that is
important, but the fact that the distance is CHANGING)
[Edited on 1/10/08 by ravingfool]
jeffw
| posted on 1/10/08 at 02:00 PM |
Just to clarify ..this will be a Doppler Shift radar rather than a conventional radar. It doesn't take repeated readings to measure speed.
I don't have time to explain so you'll need to look it up in Wikipedia or similar to see what I mean.
[Edited on 1/10/08 by jeffw]
RK
| posted on 1/10/08 at 02:57 PM |
I don't know, the bike speedo thing sounds a lot easier and probably a lot cheaper in the long run. Small too, and easy to set up.
I think I should go that route myself, even though I have bought a fancy set of gauges with my own custom faceplates etc. I have no idea where the
thing plugs into the car! A few things to sort before I get down to it in earnest.
