Author: Subject: Recommend an electronic speedo please
Andybarbet
posted on 12/10/08 at 08:33 PM Reply With Quote
Im after an 80mm electronic speedo, needs a black dial but with white numbers and a white pointer. Anywhere you would recommend to buy one from ?
It needs to be electronic so can someone point me in the right direction as far as what i need, im thinking along the magnets on the propshaft type of sender but do i need anything else too ??
Also, are they easy to calibrate, it will be going on a marlin roadster which is built on a marina 4 speed box and back sxle (anyone know what the diff ratio is on these ?)
Lots of questions i know !!
Regards Andy
martin1973
posted on 12/10/08 at 08:54 PM Reply With Quote
vdo vision, like westfield use in standard dash.
easy to programme, work with hall effect sender on drive shaft or prop.
martin
Humbug
posted on 12/10/08 at 09:42 PM Reply With Quote
ETB?
posted on 12/10/08 at 09:58 PM Reply With Quote
I'd suggest Greengauges. Not too expensive and fully adjustable (re colours etc).
I'd recommend ATB/Racetech speedos but they're a PITA to set-up and won't work off magnets. You'll end up getting a trigger wheel laser'd up like I did (after many hours of mental anguish....).
posted on 13/10/08 at 07:53 AM Reply With Quote
I'd also recommend Greengauges - good service & back-up. They also have good setup and calibration instructions online for preview.
LINKY
