Author: Subject: Flappy seat belts
aka Keith
posted on 24/10/08 at 11:12 AM Reply With Quote
Flappy seat belts
I have a 4 point Sabelt system in my car, but I find that the pulled straps flap around at speed.
Is there any good ways of stopping this from happening. I currently tuck them in, but it does not stop them from working loose - normally at the mose inconvenient times.
Whats the best way of stopping this?
Mr Whippy
posted on 24/10/08 at 11:13 AM Reply With Quote
sticky back velcro works a treat
stings doesn't it good smack in the face from those belts
[Edited on 24/10/08 by Mr Whippy]
matt_claydon
posted on 24/10/08 at 11:18 AM Reply With Quote
I put a cable tie through the stitched bit at the end of the loose strap and around the main part of the harness. This still allows adjustment but stopp the free end flapping around.
mookaloid
posted on 24/10/08 at 11:25 AM Reply With Quote
I have used the sabelt velcro fastening shoulder pads which do very little to pad the shoulders but they do hold the straps down and stop them flapping about
aka Keith
posted on 24/10/08 at 11:29 AM Reply With Quote
I tried the velco, it did not stay stuck to the belts for very long, and they way I had set it up meant that the straps were not fully adjustable cause the velcro pads go in the way.
I will look into the shoulder pads.
As yes, it stings when you are bumbling along and BANG you have a belt whipping around your head.
cheers
Craig
gingerprince
posted on 24/10/08 at 12:25 PM Reply With Quote
I feed mine back through the top buckle again, so the flappy bit is behind. Presto, no smack in the face!
TOO BADD
posted on 24/10/08 at 12:40 PM Reply With Quote
Cable ties for me Very offputting at speed. Legal limit of course !
posted on 24/10/08 at 12:53 PM Reply With Quote
you would have thought the belt manufacturers would have done something about this? like some velcro on the belts?
yes, it is annoying, not to mention painful but me not being a big girls frilly blouse, I just ignore it
(that and tucking them in helps too).
austin man
posted on 24/10/08 at 03:52 PM Reply With Quote
Pegs or Bulldog clips even the large Paper clips also work, The sticky velcro came undone on mine as well so not only got slapped in the face by the flailing belt also had the belt stuck in my hair
posted on 24/10/08 at 06:00 PM Reply With Quote
Someone gave me some velcro straps which work a treat. Self adhesive velcro lasted till the end of my street.
posted on 24/10/08 at 09:08 PM Reply With Quote
Ditto - gotta be the most effective (and Locost) way
dhutch
posted on 24/10/08 at 10:28 PM Reply With Quote
Yeah, thats what i did.
- Although i couldnt get it to go through the end, so its just a loop round.
Ive also seen the same done with insulation tape wond on backwards and then forwards (ie, sticky sides together, several turns). Or as mentioned above, velro wraps, which can be bought for cables and the like.
Daniel
RoadkillUK
posted on 25/10/08 at 01:52 AM Reply With Quote
I just tuck 'em under the strap, if it's tight enough, it won't work loose.
Of course that will only work if there is enough to tuck in
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
