Qucikshift
MrPoseidon - 2/5/17 at 11:33 AM
Hi .
Just purchased a quick shift from Stoneleigh Show and about to fit it to a Type9 gearbox. I'm new to kit cars and was wondering if its an easy job. Also read somewhere I should grease it well or it will rattle like crazy so which grease do I use ?
Thanks,
Nathsx - 2/5/17 at 11:49 AM
Should be fairly straight forward, not sure on the exact kit. judging by pictures on google, unbolt the top 4 bolts on existing then remove shifter assembly and replace with the new one.
Im not sure how the selector disconnects on these, you may also require some sealant or a new seal for the assembly to box
Id say a LM grease would be fine for the joint but others may have different opinions.
MrPoseidon - 2/5/17 at 12:03 PM
Thanks Nathsx - should be fun!
