All I can find out about this is that it was chapmans first spaceframe, and that the whole thing weighed 55 lbs. Tubing used was <1" diameter.
Anybody have information on this? I'm sure it is similar to the 7 but just wondered if there are pictures floating around.
Thats vi or 6 , sorry my roman's a little rusty
Don't know if it's still there, but if you do a Google (Images) for 'Lotus 7', there used to be a set of drawings that may be of use.
There is this but not sure its a Vl as they should have rounded rear
[img]upload/Chapman with chassis jpg.jpg[/img]
[img]upload/hornsey4.jpg[/img]
[Edited on 31/3/07 by Macbeast]
[img]/upload/Chapman with chassis jpg.jpg[/img]
Sod it...I've spent 2 hours trying to insert these pics. They're in my photo archive. Why does insert not work for me??
Yes I've looked at all the posts, done search etc
Image deleted by owner
Hi
The Lotus iv was an Austin Seven frame and Ford 1172 engine built for trials in 1952
great pics, thank much,
looks like alot of that tubing is 3/4 round
Only references I can find are "The tubing we used was brand-new welded furniture tube..."
and
"The MKVl chassis was to be a multi-tubular fully stressed space frame with the main body panels actually riveted to the frame's small
diameter tubes , of both round and square sections, thus providing extreme rigidity and strength yet keeping the total weight to the absolute
minimum"
Crombach- " Colin Chapman the Man and His Cars"
I will look in my archive
I'm sure i have some piccies.
Those two pics posted were of the Eleven Series 1 frame. The 6's used 1 7/8" diameter lower tubes, while the upper ones were either 1"
round or 1" square.
If you can wait till tomorrow, i can scan a bunch of pics of the 6 frame and send them to you.
Or if you want i might be able to find some Eleven chassis blueprints for you.
Rod
[Edited on 1/4/07 by cs3tcr]
The car in the foreground shows a nice early use of cycle wings instead of clamshells, though....
Try again...
This is supposed to be Lotus11 S1
I guess the chassis Chapman is holding could be Lotus 11, but the car in the foreground looks very much like a Vl
As I said, I could be wrong
[Edited on 1/4/07 by Macbeast]
The chassis in the forground was a Series 1 Super Seven, Climax powered. The 6 had a divided front axle, where as the Sevens have the lower wishbone
with top links and a sway bar.
The photo of Chunky holding the frame was a publicity photo for the "new" Eleven.
Why do i know this, i spent way too much time in my youth reading about Lotus.
There was a company making 6 clones, i cant remember their site, but they were near duplicates of the original cars.
~Rod
First what did you ment with MKIV?
the lotus 7 mk IV?
or some older stuff as the:
1948 Mark 1
1949 Mark 2
1951 Mark 3
1953 Mark 3B
1954 Mark 4
Mark 5 (never produced)
1954 Mark 6
Mark 8,9,10 (mark 6 look-a-like)
1956 Eleven
1957 Eleven series 2
1957 Lotus 7 series 1
1960 Lotus 7 series 2
1968 Lotus 7 series 3
1970 Lotus 7 series 4
1973 Caterham 7 series 3
etc
In my photo archive are some pictures of the lotus 6. (info to others)
I have more lecture, Also the caterham chassis tru the years. But not much before the seven.
Grtz
[Edited on 2/4/07 by t.j.]
He said the first space frame so it must be the Lotus Mark six
added:
Sorry cs3tcr, when I said "try again" I meant me uploading pics, not doubting you
[Edited on 2/4/07 by Macbeast]
How about this...
Lotus MKVI....
Under the skin...
