Not wanting to hijack Itsu sans build thread...
With respect to rod ends in bending.
Here's a couple of examples of things being done "wrong". Now I don't pretend to say that they're "right".
Just rather, metal doesn't care about opinions, but it does behave according to the math, so just because these cars made it work, doesn't
mean automatically its fine for you, neither on the other hand does it mean instant death by going down this path.
The one thing that I would point out is that on all the cars shown the rod end is much bigger than you might expect.
Early 1970's Ferrari...
Real Porshe 908 rear...
1985(?) Argo IMSA car was once rotary powered and now Cosworth powered...
Look at the shank diameters, they're fecking huge!
Yep. I guess someone did their maths
Those pics are very dated, as is the vehicle. These days, the wishbones would be made in one piece, with sphericals in turned housings in the ends.
The thickness of the shanks is still very relevant though, if youintend to go down this route.
Nev.
I have read somewhere (can't remember where but it has stuck in my head) that the use of rod-ends in bending is acceptable but only as a
temporary measure to determine the desired geometry then final wishbones are manufactured with spherical used.
So my question is are the wishbones available with correct geometry for the locost and sphericals used instead of rod-ends in bending?
Originally posted by onenastyviper
I have read somewhere (can't remember where but it has stuck in my head) that the use of rod-ends in bending is acceptable but only as a temporary measure to determine the desired geometry then final wishbones are manufactured with spherical used.
I can't see what's wrong....educate me?
None of the rose joints are in bending as far as i can see. The strut is attached to the bottom wishbone and i can't see that it doesn't
have a ball joint at that point it joins the hub carrier?
[Edited on 11/7/11 by Litemoth]
There was a Formula Student article posted on here some time ago, said words to the effect that Rod ends in bending were not a problem per se,
providing they were big enough. However, if they were big enough, they would be heavier than necessary therefore bad engineering and loose points!
The 'correct' use was to use them to determine settings, then replace with spherical bearings.
After all that, I'm using them on the back of my car!
Ariel Atom V8 wishbones & upright
None of the rose joints are in bending as far as i can see. The strut is attached to the bottom wishbone and i can't see that it doesn't have a ball joint at that point it joins the hub carrier?
how is that different to the transit top ball joints used on many cars? Just that the transit ones are larger diameter?
I have managed to slightly bend a set of ball joints, but that was only on hitting a toyota!
It's no different to the transit drag link ends - they are also being "abused" in the same way on locosts and westfields etc. though they do have pretty hefty shanks and failures seem to be very rare.
If your car had this already and you was worried i would set up the rose joints then sleeve with a piece of suitable thick wall tube. we use this
method at work often and makes it really as strong as a piece of solid bar, weighs about the same too!!
Solves the problem though if there is one!!ably sized
I suppose it is an issue of perspective in design optimisation: do you settle for rod-ends in bending or do you go that extra step, refine the design
and end up with a more elegant solution?
This is all fascinating.
Originally posted by bi22le
If your car had this already and you was worried i would set up the rose joints then sleeve with a piece of suitable thick wall tube. we use this method at work often and makes it really as strong as a piece of solid bar, weighs about the same too!!
In my opinion in this picture the bottom ball joint is not suitable for this application There are much greater bending forces than on the top and the steering joints because the suspension (spring) mounting is bearing on it. This would create a potential fatigue fracture where the threads on the rod shank create a natural starting point for a crack to form.
I do not say that this is the way "it should be done" but I am in the very slow process of making wishbones without side loaded threads. In
the picture the finished parts (with holes in their hears) are for the inner top joints and the unfinished short fat ones are for the outer top.
Various wishbone bits
I recall an engineer friend saying to me once how cutting a thread on a rod decreases it's strength significantly. If you put a coarse metric thread on a rod, you reduce its effective diameter by one millimeter but the act of cutting the thread and the stresses it produces make the real reduction in strength more than just reducing the diameter by one millimeter. I'm sure that this mainly refers to cut threads and not rolled ones, I think rolled threads are significanltly less problematic where it comes to stresses.
quote:In my opinion in this picture the bottom ball joint is not suitable for this application
Has any one got any pictures of how it should be done?
Audi R8...
Old thread perhaps,
But, the audi ones are minebea, which is the same GD uses on their T70 cars, not cheap but very very VERY strong. look into those when dealing with
higher weight or performance cars. I asked Andy burrows wheter it would be more cost effectie to put something cheaper in it awnser was "yes, but
I wouldn't drive it" nuff said realy.
grtz Thomas
The Audi has done it correctly, there are no rod ends in that other than the toe link and that's not in bending.
