I'm running Wilwood Powerlite 4-pot handbrake calipers at the front on 240mm x 11mm solid discs. More than enough!
The fabrication for the single-sided swingarm hasn't started yet, so I can have whatever I want. I fancy something trick and have found a set of
MV Agusta rear 4-pots for a 240mm x 6mm disc. Can anyone see any problems if I was to run this?
Or, should I just get another Wilwood (non-HB) Powerlite for the back on a 240mm x 11mm disc?
MV Agusta 4-Pot...
Looks the same as the caliper on my old GSXR600.
Surely a caliper is a caliper? If i had a trike (heavier than a bike) i think id have a car caliper and disc to stop it.
