Hi all.
I have a zzr1100 powered tadpole. At around 60+mph the back end feels squirally and loose and suspect I could do with an alignment check. Can anyone
recommend somebody in the north west, cheshire, south manchester, derbyshire areas? Thanks Mike.
I can thoroughly recommend http://trackroadandrace.com/default.aspx
pity they might be a bit far for you tho?
Cheers pal, yeah its a little bit far but always an option. Keep the suggestions coming.
A rough location in your profile will help when posting questions like this.
I've got a workshop in Stalybridge but I've no idea where to start with checking the alignment on a reverse trike.
Done that :-)
