For my reverse trike I'm using some old honda comstar wheels. Originally I was going to take them apart and make a new center section that would
mate up to my car hubs. Now that I've taken them apart I thought it would make more sense to make a whole new wheel center that could bolt on
(like a split rim wheel). This would be better than a modified center as I could keep the width of the trike down by a few inches.
My questions are, how's the best way of doing this? Single circle of aluminium? If so what thickness? 12mm? Laser cut steel? thinner metal and
re-enforcing? The original spokes are 3mm ally, 2 sets of 5 (second pillar drill pic shows 5 gone and 5 remaining)
Sorry i can't help you, i just posted this do i can keep an eye on how these wheels turn out! Best of luck!
Can't you keep the old Comstar "spokes" and make up a smaller disc for the center? It would be lighter and cheaper. Plus thats the bit
that takes most bending load so you know it wil be as strong as the original (if that is strong enough for your application).
Split rims use around 12mm thick castingsar the outer edge rising to 50 to 75mm thick in the center - but this has more to do with offset I think.
It may be easier to centralise a smaller disc than a larger disc - just 'cos its easier to work with and if you foul up there is not so much
stuff wasted.
My split rims have steel inserts where the nuts locate and the alloy has to be thicker there. Bearing in mind your low weight it should be possible to
replace the studs with 10.8 bolts and washers so you would not need the thickness and could use 12mm alloy. In this case you will need to centralise
the wheel, not on the studs, but on the lip provided for just this purpose on the hub.
All in all I'd turn them up on a lathe rather than laser/water cut as I feel it would be more accurate at cetralising the boltholes to the center
cutout. Just a feeling I guess there is at least one expert on here who can confirm or otherwise
Interesting
Cheers!
Thanks for the info!
Originally posted by v8kid
Can't you keep the old Comstar "spokes" and make up a smaller disc for the center? It would be lighter and cheaper. Plus thats the bit that takes most bending load so you know it wil be as strong as the original (if that is strong enough for your application).
Humm. No real advice, but I would be worried about getting this correct, I guess the old motor cycle spider is not suitable as on a bike I guess all
the force is along the spokes you don't really get any sideways forces (or you would fall off, though centripetal forces might cause some??)?? So
I guess you can't use the original spider anyway on a car/trike??
[Edited on 2/2/12 by Bluemoon]
Originally posted by Bluemoon
Humm. No real advice, but I would be worried about getting this correct, I guess the old motor cycle spider is not suitable as on a bike I guess all the force is along the spokes you don't really get any sideways forces (or you would fall off, though centripetal forces might cause some??)?? So I guess you can't use the original spider anyway on a car/trike??
Don't think a disc of 12mm to fill the whole inside would be strong enough you would need reinforcing ribs of some sort and the cost would be far higher than second hand bits.
99p! You were done not worth a penny over 97p
Why can't I get these bargains?
