This illustrates the general arrangement of the main components
[img]
[/img]
And this the packaging within locost type chassis
[img]
[/img]
[Edited on 4/7/12 by martinslyon]
Aluminium panels and wheels attached
[img]
[/img]
First assembly mock-up
[img]
[/img]
Showing monoshock linkage
[img]
[/img]
Simple and elegant front wheel drive upright
[img]http://
[/img]
Front corner with drive shaft
[img]http://
[/img]
Will post more soon, would be interested to receive feedback and comments?
Monoshock linkage detail
[img]http://
[/img]
Labelled schematic
[img]http://
[/img]
Bottom view
[img]http://
[/img]
That all looks very impressive.
Pardon me if I've missed something, but what resists chassis roll in cornering with that setup?
Fred W B
Fabricated swinging arm - similar to this.........
[img]http://
[/img]
But I'm going to use this for now...........
[img]http://
[/img]
well impressive, what are you using for batteries?
Fred W B
Wow. Nice work. Keep at it.
Budget allowing - lithium-ion mounted on the floor where conveniant and low down on the outside of the main chassis in shaped aero pods.
Thank you for your interest.
Regards Martin
This is my Ohlins monoshock - allegedly from a Van Diemen single seater??
[img]http://
[/img]
Regards Martin
What kind of range are you looking for? That is gong to be some kit when it is done,..
Like the idea ........
What electronics are you using ?
What Voltage are you running at ?
DC or AC drive ?
Are you using regen braking ?
Keep[ up the good work
RD
Hi Martin
I had a really good look at your pictures last week as its of real interest to me as I am also interested in an electric vehicle build. Mine is also a
single seat as I would like to use it as my daily driver to work (120miles round trip). I was looking at either a warp motor or a couple of agni
motors with lithium ion batteries. It started as a car with 4 wheels but i had come to conclusion that to lose weight a wheel needed to be
sacrificed. I'm no where near as far along as you appear but thanks for re invigorating my interest in the project.
Heres a picture of what I am think of,
[img]
trike
[/img]
Please keep up the great work.
cheers Pete
Have you calculated the magnitude of the stresses that will be seen in the front suspension? The extremely shallow angle of your pushrods means there is going to be a very large compressive force on them and the bracket on the upright (and equally large tensile forces on the top wishbones). I don't wish to be negative but gut feel says that something is going to bend.
Originally posted by watsonpj
Hi Martin
I had a really good look at your pictures last week as its of real interest to me as I am also interested in an electric vehicle build. Mine is also a single seat as I would like to use it as my daily driver to work (120miles round trip). I was looking at either a warp motor or a couple of agni motors with lithium ion batteries. It started as a car with 4 wheels but i had come to conclusion that to lose weight a wheel needed to be sacrificed. I'm no where near as far along as you appear but thanks for re invigorating my interest in the project.
[img]
trike [/img]
Please keep up the great work. cheers Pete
DC or AC drive ?
RD
Loving this. Great work.
A guy at my old place made a really neat 4 wheel electric car (he's made two actually) both really well engineered, he had hte luxory of a very
nice battery system for next to nothing.
Just a thought but could you not design it so the electric motor is chain driven to the rear wheel thus loosing the weight of the diff and drive
shafts. Not sure on final drive ratios and motor torque but purely from a weight saving perspective?
I like it so far, though for real efficiency I'd have dumped the wide tyres, the rolling friction from almost 3ft of tread will kill your battery
and performance and harm streamlining
I wish such cars had separate roads from other traffic then I’d have been building one too
[Edited on 5/7/12 by Mr Whippy]
I like the system as electric motors can produce significant torque from a standstill, so 2wd is better than 1wd. However as you say there are issues
of efficiency and losses from the diff.
Battery weight and position will be important, especially so for cornering.
As for tyres, I am sure that the use of more narrow wheels will help. I was told that on the Volvo V40 the use of 195 tyres gave 99g/km CO2, but
215's increased that by 3% and put the vehicle into another tax bracket(!)
It is an interesting idea, and I shall watch and learn, much better than the TG electo-toy-disaster
only other point is the chassis top rails at the cockpit edge, the way you have it designed, if you were rear ended the area of the chassis that would crumple or fold up is where you are sitting... I'd want to beef that section up alot perhaps use larger or doubled up tubing, even a x-brace rather than just a plain diagonal
[img]http://
[/img]
[img]http://
[/img]
[img]
[/img]
[img]http://
[/img]
[img]http://
[/img]
[img]http://
tr8
[/img]
[img]http://
tr9
[/img]
[img]http://
tr10
[/img]
[img]http://
Description [/img]
[img]http://
Description [/img]
Do my eyes fool me or is that a 4 wheeler not a trike
And it looks AWSSSUMMMMmmmmly sweet, yes I like that a lot
[img]http://
Description [/img]
[img]http://
[/img]
[img]http://
[/img]
[Edited on 6/7/12 by martinslyon]
[img]http://
[/img]
[img]http://
[/img]
[img]http://
Description [/img]
[img]http://
tr8 [/img]
[img]http://
tr8 [/img]
Has your design now changed? This is a more conventional layout for the pushrods, operating on the lower wishbones and avoiding the shallow angles of the original.
