Hi
I am planning a reverse trike build. I need to tidy up and MOT my tiger to sell so I have a budget for this build.
The question I cannot find an answer for is: do I need reverse gear?
I looked on the DVLA website and looked at the MSVA manual. It didn't mention it anywhere I can see. This either means I don't need it or I
missed it in the text.
Any help appreciated
Dan
Pretty sure its not required. Even road registered quads dont have them. Cars only.
Thank you
What engine/transmission do you have planned for your reverse trike.
Presumably one from a motorbike?
Sports bike. 750 or bigger. Not really sure. I'm not a bike guy at all. So I have some homework to do.
I'll use commercially available front wishbones and geometry from the locost book.
There won't be much else to it. I want it simple and exciting
Dan
Understood.
Past experience has shown me that a letter to the DVLA often works and gives you written clarification from them.
I've been thinking along the same lines, but a more traditional type ala Morgan, I think the easiest engine to use is a moto guzzi, it's
across the frame and shaft drive so very simple to set up, air cooled as well.
Shooter
Thanks shooter. That's definitely worth considering
Nick205, good idea. If I have a peice of paper it will put my mind at ease. Something to show plod too
Dan
I am currently building a reverse leaning suspension trike and from my home work you do not need a reverse but it depends on finished weight. you will however need a parking brake !
