Hi everyone,
I am wiring my reverse trike and am using 99% of the bike wiring loom. I am basically extending all the wires from the loom to the dash area for new
switches etc.
Question is: the bike lights come on with ignition. Is this ok for MSVA? Should I rewire this? Or is it ok to have side lights/headlights come on with
ignition (like an old Volvo)
Any thoughts?
Dan
Does anybody know the answer?
Dan
Hi Dan, I'm new to the Trike regs, but having read the MSVA manual so far as I can see there is no requirement to be able to switch sidelamps
separately, in other words, no requirement for a parking light. When sidelights are turned on (with ignition if that's how they are) the way I
read it is that they must all be illuminated, front & rear & that includes the no. plate light & that they should operate a tell tale
light, OR the instrument lights are always on when sidelamps are lit.
You may of course decide you'd like to have parking lights in which case a switch from a permanent feed could be put into the sidelight circuit,
just add a diode in the ignition live wire so it can't back feed to the ignition
