Things for sale (wheels, carbs, sump)
Coose - 31/8/09 at 11:46 AM
Afternoon all,
I'm having a garage clearout and have a few bits to sell and thought that I would offer them here before facing the wrath of eSkip. They are all located near York but I may be able to deliver/meet you somewhere as I tend to get around the country a bit: -
Ally Cat Wheels
Two pairs, both 6" x 14", ET16 offset in pretty good, straight condition. One pair have a pcd of 108mm (Ford etc.) and the other 100mm (Vauxhall, Triumph etc.). They were taken off my old Striker when I changed to Ford front uprights and 13" wheels. They would benefit from a polish and repaint as some of the paint is lifting, with a bit of minor corrosion underneath (one pic shows the about the worst of it). Make me an offer for either the set of four or per pair.
100mm pcd wheels: -
VX Wheels
VX Wheels
VX2
VX2
The worst of the corrosion: -
VX corrosion
VX corrosion
108mm pcd wheels: -
Ford Wheels
Ford Wheels
Weber carbs
Two Weber downdraught carbs, one is a DVAG 32 (the one not on the manifold), the other is unknown as I can't find any markings and would probably only be good for spares.
I think that I once used the DGAV 32 on my old 1300 x-flow and it seemed to be ok, though has been sat in the garage for the last few years. Again, make an offer.
Carbs: -
Carb1
Carb1
DGAV 32
DGAV 32
Other Weber
Other Weber
Chopped Zetec sump
This belongs to a friend and was bought with a Zetec, but I couldn't tell you which so I don't know which one it will fit. It has been chopped and baffled but it wouldn't fit in his Cateringvan and so he ended up buying one from elsewhere. I don't know if it leaks but the welds look ok. Again, make an offer if you're interested!
Sump: -
Sump1
Sump1
Sump2
Sump2
Sump3
Sump3
Sump4
Sump4
Sump5
Sump5
Coose - 8/9/09 at 07:24 AM
Boing!
bmseven - 9/9/09 at 08:20 PM
I'm confused, the Ford/Triumph rims are they metric or imperial PCD?
Thx
Coose - 13/9/09 at 09:11 PM
Ok, I may be wrong. The ones that I said were 100mm pcd may not be, but they came off the front of my Striker that used Vauxhall Viva uprights so Google says that they will be 101.8mm. The other pair are definitely 108mm (straight off an English live axle).
So, the non-Ford pair are Vauxhall Viva fitment and will not fit Triumph Herald uprights (which were 3.75" pcd). I'll measure them tomorrow if you are interested.
richyb - 14/9/09 at 04:04 PM
you have U2U re sump
owelly - 14/9/09 at 07:50 PM
Cooooooooose! The Viva ones will be 4" PCD or 101.8mm........
Coose - 14/9/09 at 08:20 PM
Aye, thy is correct old bean! I was wrong but now I'm not!
Coose - 2/10/09 at 07:05 PM
Sump now sold. The rest is still available.
zilspeed - 3/10/09 at 12:20 PM
Those would fit ye olde Sylva...
What are we talking for the ones with the 4" PCD ?
Coose - 4/10/09 at 08:59 PM
Aye, that they would as that's what they came off!
As I said in the ad., make me an offer!
