Martin keenan alloy fuel tank.
2" filler 8mm outlet and 1x8mm breather/ return.
About 760mm long 230mm high 170mm deep on the bottom and 160mm deep on the top.
Has had a five hole telemetrix gauge sender fitted see pic
Comes with two powder coated steel straps.
Its had fuel in but its not been on the road so its very clean and tidy.
pic1
As its had fuel in I dont want to post it.
So £50 and come pick it up.
Edis6 (sold Pete)
Edis4 kit
Ver very clean edis, coil, cap, vr sensor and loom. Ive used this to test all sorts of engines. just two wires to run, power and earth There is also
a tacho output and the shielded pip/saw lead.
£45 + £5 postage
edis4 (sold Jamster)
edis4 broken prong on plug. (sold Hugh_)
early zetec coil and plug
£5 + £5 postage
pic2
zetec steel inlet flange ( sold Mike)
Zetec Stainless flange and stainless 4" tube aswell as stainless tube to make a turbo plenum/ griffin style manifold.
£40 + £7 postage
pic4
1992 escort Rs1800i "HO" inlet manifold complete. Its had a good clean and is complete
£50 + £12 postage
Rover 25 header tank and bracket.
£5 + £5 postage
pic5
M14 to 1/8ntp adapter £2 + £1 postage
unleaded ring to go in filler cap. £2 + £1 postage
zetec thermostat housing and sensors £5 + £5 postage
pic9
Bits that are meant to be a Mondeo induction kit. Poor quality but some one may want to do somthing with them.
Mk1 maf screws into it to make it neater.
pic6
toad cat B Immobiliser. No instructions and no cert' will provide wiring diagram. has two touch keys. It been fitted and pulled out so not
mint.
£5 + £4 postage
pic10
I am sure I will find more.
[Edited on 8/5/10 by big_wasa]
U2U sent re. unleaded insert
U2U ref zetec steel inlet flange
Mike.
U2U re EDIS with short tails.
can i take edis 4 and plug and tails thanks £12
U2U - Re: EDIS 4 KIT.
U2U sent
Hi Big Wasa, just checking sizes for Fuel Tank... Will let you know asap.
Rich
Do you know about the tank yet wasa as I will be travelling up to Grantham soon and take it thats not far from you?
Update as I can not edit listing.
Sold pending ect Wumps
Edis6 (sold Pete)
Edis4 kit (sold karlak )
toad cat B Immobiliser. (Sold Dan )
£40 + £7 postage
pic4
£50 + £12 postage
Bellow are free if you collect
£5 + £5 postage
£5 + £5 postage
pic2
pic5
pic9
pic6
