Dax Rush Cosworth Project
FlansS14 - 8/1/13 at 05:17 PM
Not super locost but fun none the less
We purchased this some years ago and not found the time to finish it off. This kit is 98.7% complete, the only parts required would be engine loon/ecu, a fuel pump and a few small parts. The rest is all there and just requires elbow grease and basic mechanical knowledge (not included)
The car has had a huge amount spent on it, here is a rough list (im sure ive forgotten half the stuff!!)
Brand new Chassis with offset hoop and Deon set up
Black GRP bodywork and chrome sidekicks
(the above was over £3000 alone)
Dax custom seat, torno cover..etc (another £800)
CI gauges with all the loom and fusebox (also demist units)
Gaz Shocks with correct springs
17” Wheels with wider rears (205/40/17 and 245/40/17) Toyo Proxies
Cosworth big brake kit
All braided lines, new master cylinders, res, sensor etc
Cosworth LSD 7.5” Diff
New Screen
Headlights,radiator, lots of hoses,clips, trip bits.
Engine
Early 90’s Sapphire Cosworth engine with the 200 block
Full rebuild last year at Burton Power (new bearings, oil pump, water pump, rings, group A Gaskets) £750 receipt
The head was rebuild with all new valve stem sills and new hydro lifters. Also setup std duration on the cams (Adjustable verniers) £500
All new gaskets and seals
Green injectors
Top mount manifold
Stage 3 T34 turbo with a 0.48 a/r housing
Dax exhaust system £650
Cosworth t5 Gearbow with CNC Quickshift kit
Paddle Clutch
Price
Offers around £7500
Cosworth setup (engine,box,ancs) £2500
Rolling chassis £5000
This is from memory, hopefully explain it better. Also please not the rocker cover has been professionally painted fluorescent orange (its bright!!!!) so bright it effects my camera so I apologise for the strange pics. Any info please do not hesitate to contact me, a test ride (push) can be arranged on request. It will be a shame to see her go but ive ran out of time.
pics ( i hope this works???)
http://s13.beta.photobucket.com/user/FlansS14/library/Dax%20Rush
All the best
Flan
CrazyBike - 11/5/13 at 11:05 AM
Hi.
Have you sold your car ? I'm from France and i would enjoy to get a Dax Rush... and finish it could be a nice challenge..
Keep me informed, it could interest me...
B.regards
ST
