hi
how much would i be looking to spending buy a 2l pinto?????
cheers
How long is a piece of string £50 to £10,000 depending on tuning
what sort of performance are you after?
i dont really mind what performance i just want a small project so i thought of an engine rebuild, and if all goes well put it in a car at a later date.
Keep an eye on eBay and you'll pick one up for <£100 suitable for a rebuild project. If you're planning on fitting it to a car in the
future you may want to avoid engines from Transits (low compression IIRC). By the same token you might look (and pay slightly more) for a later
injection spec engine (better inlet ports/more power IIRC). Parts are cheap and plentiful too.
[Edited on 1/4/12 by nick205]
