As title really..
Does anyone have any mild steel or stainless tube approx 400mm long and 100mm in diameter?
I/D or O/D? What wall thickness?
It is not too critical. 2-4mm wall thickness would be ok.
I've got some 104mm o/d x 2mm wall or 4" x 14g both in stainless steel. Probably be about £15-£20 plus the postage if either of those is any good.
I have some 4" nominal bore steam pipe so probably 4mm wall thickness. Any good?
Owelly, is that 100mm OD with (roughly)4mm walls?
[Edited on 13/3/13 by tegwin]
It's 4.1" I/D with 4mm wall (could be a bit thicker).
Hmmm. Thanks for the offer but I think it's just too chunky.
Might have to resort to ebay for a 100mm ID with 3mm walls...
