kipper
posted on 7/6/09 at 05:27 PM |
reverse /handbrakes for 3 wheeler
Does anyone have the new iva rules.
I need to know if I will need to fit reverse and hand brakes to my build.
Three wheeler, two at front one at rear.
Denis.
Where did that go?
mangogrooveworkshop
posted on 7/6/09 at 05:34 PM |
for handbrake saab or citreon have front handbrakes
ab engineering are good for lectrical reverse
smart51
posted on 7/6/09 at 05:40 PM |
I think 3 wheelers are tested under MSVA rather than IVA. If that's true (I really hope it is) there's no requirement for reverse.
For handbrake you have to brake all the wheels on 1 axle, so both fronts or the single rear. You have to achieve a percentage of the vehicle's
weight as handbrake force. Obviously that's easier spread over 2 wheels than 1. You have to have a secondary braking system which can either
be a split main brake system or the handbrake. The percentage for this is higher than for the handbrake.
My trike has a dash pull handbrake driving both front wheels. Theoretically it could achieve the same brake force as the foot pedal on the front
axle. You'd have to pull it hard though. The front axle makes more brake force than the rear so I'm guessing I'll be OK.
kipper
posted on 7/6/09 at 05:52 PM |
three wheel reverse
Thanks for that smart51,
I hope you are right.
Is there a iva download anywhere yet?
Denis.
Where did that go?
Flamez
posted on 7/6/09 at 06:06 PM |
Denis.
Blakep82 has a link on his signature to a free download of iva
my build mac1motorsports
smart51
posted on 7/6/09 at 06:29 PM |
Hot from the MSVA manual:
You must have two independent service brakes or a single line brake plus an emergency brake which can be the hand brake.
Front brakes 28.5%
Rear brake 28.5%
combined service brake 50%
secondary brake 23%
parking brake 18%
where the percentage is the braking force / laden weight, where the laden weight is the unladen weight + 75kg for each seat.
iank
posted on 7/6/09 at 07:04 PM |
Denis.
The version for free download direct from VOSA is more up to date.
http://www.transportoffice.gov.uk/crt/vehicledealershipsandimporters/isocertificationandtypeapproval/individualvehicleapprovalinspectionmanuals.htm
Anonymous
RichardK
posted on 7/6/09 at 08:07 PM |
Interesting doc that, first thing I've noticed and wasn't aware of:
6. A system of head restraint must be fitted on every outboard front seat.
Cheers Rich
Gallery updated 11/01/2011
matt_claydon
posted on 7/6/09 at 08:28 PM |
3-wheelers, unless VERY heavy, will be tested under Motorcycle SVA (no IVA here). The requiremts are really very easy compared to car IVA or the old
car SVA.
smart51
posted on 7/6/09 at 08:57 PM |
car SVA.
I thought you just weren't allowed a 3 wheeler over a tonne?
kipper
posted on 8/6/09 at 03:15 PM |
Hand brake
I have just picked up a calliper from a Suzuki burgman scooter which has a mechanical handbrake incorparated.
I will try to replace the piaggio rear calliper with the Suzuki one . Hope it works.
Where did that go?
