Micke Fredriksson
posted on 29/9/05 at 07:45 PM |
Hello!! Well some kind of traction control would be nice! But the grip problem isn´t a big deal if the tarmac is fine. The time where so bad I rather
not say it....
The topspeed: 137km/h (201m)
60 foot: 3.1sec
I will make much better next year!! I hope I will get some trackday time in it next year too. It´s almoste to cold up here in sweden now to drive a
open vehicle.
quote: Originally posted by akumabito
...traction control maybe? Or launch control perhaps..
What was your best time on the track?
[Edited on 28/9/05 by akumabito]
/ Micke Fredriksson
akumabito
posted on 30/9/05 at 10:59 AM |
Racelogic sells aftermarket traction control... comes with launch control build in too... pretty nice, I guess it would make a lot of difference on
your beast.. it's expensive though..
http://www.racelogic.co.uk/?show=Traction_Control
Micke Fredriksson
posted on 26/12/05 at 01:24 AM |
This is a Video from a Trackday at Midlanda motorpark in the middle of Sweden. 2005-10-08 with my T42 turbo.
Turbo boost: 1.0bar = 300hp+
(save as)
FILM: Trackday Mride T42 Turbo
/ Micke Fredriksson
wacomuk
posted on 30/12/05 at 12:40 AM |
linky no worky
Micke Fredriksson
posted on 30/12/05 at 06:58 AM |
quote: Originally posted by wacomuk
linky no worky
Hi!! Hmm. Yes I know. because there have been more then 2200 downloads in two days, my webhotel decided that I´ve passed the downlload limit on this
file..
If you want to see the film, you can visit my site and download it from there. www.mride.se
/ Micke Fredriksson
Micke Fredriksson
posted on 17/1/06 at 09:57 PM |
A real hardtop on the T42 trike!! Just a photoshop picture but I like it VERY much, and perhaps I have to make one next vinter.
[Edited on 17/1/06 by Micke Fredriksson]
Micke Fredriksson
posted on 18/3/06 at 11:10 AM |
After the paintjob and striping I have started to mount it together.
More pictures: MRIDE.SE
[Edited on 18/3/06 by Micke Fredriksson]
/ Micke Fredriksson
sean951
posted on 19/3/06 at 05:54 PM |
wow! that is stunning! it looks amazing Micke!
Micke Fredriksson
posted on 20/3/06 at 09:35 AM |
Thanks man!!!!
/ Micke Fredriksson
soggy
posted on 21/3/06 at 12:45 AM |
hi micke i have followed your build from the start and it just gets better!
awesome.
if at first u dont succeed use a bigger hammer!
chrisf
posted on 21/3/06 at 01:20 AM |
Hi Micke:
Did you primer/paint the inside of the bodywork first? I am almost ready to paint my locost but cannot figure out if I need to paint inside of the
fiberglass.
Oh, the the bodywork came out very, very nice. Well done man!
--Chris
Micke Fredriksson
posted on 22/3/06 at 03:48 PM |
THANKS!!!!! I´m glad you guys like it!!
I primed and painted the inside of some "not every" panel first. And after that I took the outside. less masking!
You doesn´t need to paint the inside of the fiberglass if you don´t want to. If the raw fiberglass is exposed to UV-light for a long time the
polyester will change color and turn crisp and fragile... One layer of paint will privent that. But the question is how much sunlight will come in
there? Probably it will take more then 15years before it happens.. But better safe then sorry.
/ Micke Fredriksson
akumabito
posted on 24/3/06 at 11:34 AM |
Now THAT looks awesome!
Micke Fredriksson
posted on 26/3/06 at 09:53 AM |
THANKS !!!! To bad I can´t afford to build the carbonfibre hardtop right now... I think too that the T42 looks awsome with it!!
I have two new short video clips on my websight- You are all welcome to take a look!! www.mride.se
/ Micke Fredriksson
cita2
posted on 28/3/06 at 07:47 PM |
You'dd better secure that roof very good!!!!
It's a bloody wing and the air trap near the top of the front shield will form a perfect leading edge!!
.........it looks VERY neat though
Micke Fredriksson
posted on 29/3/06 at 08:22 PM |
Thanks!! Yes, you have a point there about the roof. But I don´t think that the lift on the roof section will be a problem. Aerodynamic lift is often
generated by negativ pressure zones and turbulens.
If you have a large surface where the airstreem goes only one direction, and have nowhere else to go but over it. The lift effekt will be very
powerful - like a airplane wing.
The T42 roof design is very narrow- only about 75cm. Most likely there will be a high pressure zone in the front of the window and upp till the
highest point of the roof and goes over to a slightly low presure zone right over the passenger. And because of that the body continues after the
roof shape, there will not be turbulens over the roof. The window shape will only push perhaps about 30% of the comming air over the roof and the rest
out on the sides. The low pressure zone over the passenger will suck in some of the side streems and fill it out, which will reduce the lift over the
passenger.
The front airvent scoop on the roof will "slice" the air (like cheese). This "slicing" will not generate lift, but it will add
air pressure inside the cabin, and high cabin pressure will pop the roof off if the pressure is to high. I will mount a air lock so I can close the
scoop. But if you build a air intake you MUST build a air outlet, to prevent this high cabin pressure and make a good ventilation.
I´m perhaps not a trained aerodynamic engineer, but I have been in contact with one and disscussed the roof design. And I think the roof will make the
T42 trike faster in speeds over 200km/h - cause of less drag of cockpit turbulens as a open vehicle..
I hope you understand me and my swenglish
[Edited on 29/3/06 by Micke Fredriksson]
/ Micke Fredriksson
cita2
posted on 30/3/06 at 07:15 PM |
Hi Micke,
I'm by no means a aerodynamic specialist either but from the moment air is moved over a surface the pressure will drop,or explained in another
way,will create lift.
I'm not worried by the air that will be deflected by the windshield but the undeflected air that will meet the front,or leading edge,of the
curved roof.
75 cm doesn't seem much but a wing section of 75 cm wide and of chord of over 1 meter (lenght of roof) will produce a significant amount of lift
at speeds of 200 kmph!!!!
Your airscoop will have to be of excelent design to transport all the air that is gathered at the intake at high speeds or it will form a buffer and
this buffer will be compressed into a near perfect leading edge.
Most lift is created in the first quarter of the foil and if it's true that the flowing airstream will follow the roof almost till the end of
the roof,it will only create more lift.
I hope I'm completely wrong on this (have been before) and that the roof stays on!!
Dont,by any means,let my opinion prevent you from building that roof and test it!!
cheers,
cita
Micke Fredriksson
posted on 3/4/06 at 08:34 PM |
Vetsanding and polishing the paint.
Hella 2" projektor and 3" highbeams
Fram a solid aluminium axel a CNC macin made the houings from my drawing.
The final finish.
ScothBright fabric makes the "brushed" finish. SUPERB!!
Front wheels newly painted. Really cool!!
/ Micke Fredriksson
Mave
posted on 7/4/06 at 05:17 PM |
Hej Micke,
it's looking awesome! Also an excelent choice of colour; very classy.
Is the front part of your headlight an original Hella part (the silver part with the grooves)? I've been trying to find something similar for my
car, but haven't been able to find them. So now I have ordinary 5 3/4" light...
Marcel
Micke Fredriksson
posted on 7/4/06 at 07:12 PM |
quote: Originally posted by Mave
Hej Micke,
Marcel
Hi!! Thanks!!
Yes the front part of the headlight is original Hella. 2" lens.
/ Micke Fredriksson
Micke Fredriksson
posted on 16/4/06 at 08:03 PM |
The Mride T42 turbo trike is now finished after mutchous of work!!
Do you like it as it turned out?
[Edited on 16/4/06 by Micke Fredriksson]
Spyderman
posted on 17/4/06 at 02:18 PM |
That looks amazing now it is painted Micke!
You must be very proud! Nice colour by the way.
I take it you decided against the bare carbon fibre look in the end?
Terry
Spyderman
Micke Fredriksson
posted on 22/4/06 at 11:02 PM |
The spring is finally here in the north of Sweden!!!!
/ Micke Fredriksson
Micke Fredriksson
posted on 3/5/06 at 07:51 PM |
/ Micke Fredriksson
