spdpug98
posted on 27/1/09 at 05:47 PM |
Brake Balance Bar Fitting
I know I am going to regret this question, as I am sure the answer is staring me in the face, I have done a search but can only find answers on how to
set it up
I have fitted the pedal box and the master cylinders, I am trying to fit the balance bar but cannot work out how to screw it in and keep the clevises
in place, I hope this makes sense
Thanks in advance
My Blog: http://spdpug98.wordpress.com/
John Bonnett
posted on 27/1/09 at 05:53 PM |
This was the set up I used on the Phoenix
blakep82
posted on 27/1/09 at 06:11 PM |
how far did you screw the clevis on the push rod?
________________________
spdpug98
posted on 27/1/09 at 06:28 PM |
Tried with just a few turns and then up until I could see the thread through the other end.
Its just if I have the bar screwed into one master cyclinder and as I try and screw it into the other the original unscrews it self
MkII
posted on 27/1/09 at 07:03 PM |
not quite sure i understand your problem but you need to thread the clevis's onto the balance bar first then wind the push rods into the
clevis.is that any help?.m.
spdpug98
posted on 27/1/09 at 07:34 PM |
I didn't really know how to ask, but you have explained it, I didn't think you could turn the push rods but now i know it should be easy
gr8ging
posted on 29/1/09 at 12:47 PM |
I had exactly the same problem, spent ages trying to work it out. A friend told me it was ok to turn the push rods. Sorted in no time. I did cut the
clips off of the cylider boots to make it easier as the boots kept twisting, then replaced clips with tiny cable ties once set.
Weaseling out of things is what separates us from the animals.... except the weasel.
You couldn't fool your own mother on the foolingest day of your life with an electrified fooling machine!
spdpug98
posted on 29/1/09 at 03:43 PM |
All sorted now, thanks for all the replies
