speedyxjs
posted on 16/7/09 at 11:45 AM |
Fuel return
Does the fuel return need to go back to the tank or swirl pot or can i put a T-piece in the fuel inlet?
shortie
posted on 16/7/09 at 11:46 AM |
Back to tank
omega0684
posted on 16/7/09 at 12:06 PM |
tank
breather/over flow from swirl pop should go back to tank as well
[Edited on 16/7/09 by omega0684]
speedyxjs
posted on 16/7/09 at 12:12 PM |
I dont have a swirl pot, or an return feed to the tank.
Is there any way to have the return feed into the filler pipe?
posted on 16/7/09 at 12:31 PM |
Yes, you can have the return going back to the filler neck. I can remember my dads Metro Turbo used this method as you could see the fuel coming out
of the return if you looked down the filler neck with the engine running.
posted on 16/7/09 at 02:47 PM |
You can have it returning to a T in the fuel line. Only problem will be you'll have the same fuel wizzing round and round the engine bay so it
will get hot and you may get a problem with vapour locking....
