Aled_g
posted on 16/2/10 at 02:05 PM |
Spring Rates
Anyone know what's a good spring rate for a double wishbones suspension on a locost? looking for a fairly stiff setup but not so stiff there is
no travel. Using 402lbs/in on the front, cheers
Danozeman
posted on 16/2/10 at 02:13 PM |
what engine have you got. The weight will make a difference. I would say 400 on the front is too heavy. Mine with a zetec im using either 200 or
250 cant remember which up front and its just right.
Dan
atm92484
posted on 16/2/10 at 02:49 PM |
Any idea of the motion ratio?
-Andrew
Build Log
DavidM
posted on 16/2/10 at 07:28 PM |
I've a crossflow powered car, which I built using 275 front and 175 rear. I've since changed the rear to 150's and I am about to
change the front to 225's.
If it's a road car you'll find that the condition of the roads will seriously limit its performance if the springs are too stiff.
Proportion is Everything
