Bass1st
posted on 2/3/10 at 09:15 PM |
4age Breather?
I am running a 4age with DHLA 45's and an Omex 150 ecu. On the carb side of the cam cover about half way down there is a breather pipe which
just hangs down through the engine bay. I assume this used to be attached to the injector system in some way before the carb conversion. Is it OK to
leave it in this state or should I invest in a breather or catch tank?
tul214
posted on 2/3/10 at 10:02 PM |
I had mine vented through a small pipercross filter but it does fill up. I have now plumbed it into a bottle.
1.6 Raw Super6 sold
Canada EH!
posted on 2/3/10 at 10:53 PM |
It used to go to the intake manifold. I suggest an oil catch tank, if yours came with the factory oil cooler which drains back into the oil pan you
could run a hose from the bottom of the catch tank to a T in that return line.
Bass1st
posted on 3/3/10 at 07:10 PM |
Thanks - I will buy a breather off fleabay for now, and think about a catch tank when I get some time!
