John P
posted on 8/3/10 at 06:43 PM |
Connecting Laptop to TV - What am I doing wrong?
Seems simple enough.
I've connected my Toshiba laptop to my Samsung LCD TV using a monitor type lead with seperate audio connection but simply pressing F5 which
looks like it should switch between the laptops monitor and external screen doesn't have any effect. (I know the lead is correct because
it's worked in the past).
I did have this problem at work once when connecting to a projector but eventually got it to work although it had to be either laptop or projector not
both.
Do I need to set up the display to allow me to switch between screens?
John.
blakep82
posted on 8/3/10 at 06:47 PM |
shouldn't be as simple as pressing F5. on my laptop, i have to press fn F7, fn is the little button on the bottom left of the keyboard, there
should be one on yours too
also, you need to press the input button on the telly, til you get round to one that says PC, or something
________________________
austin man
posted on 8/3/10 at 06:48 PM |
Mine is Function button and F4
tomprescott
posted on 8/3/10 at 06:51 PM |
As blake said, you'll need the function (fn) button if the f-key has a coloured icon on there (ususally purple/darkblue/grey).
Dependent on your graphics card (I'm assuming you have integrated on the your laptop) you may also have to fiddle in the control panel.
Control panel -> Appearance and themes -> Display properties -> settings
Good luck
mangogrooveworkshop
posted on 8/3/10 at 07:41 PM |
you may have to go to control panel to enable dual monitor function on those hot keys.....
had to do that a few days back
Bass1st
Make sure your TV is on the right input channel. It should make it clear on the back of the TV what input you are using. Most laptops will auto sense
a monitor and switch on, if not you need to find out what function key combo your laptop uses. Also make sure you don't have a bent pin on your
cable. Good luck.
graememk
posted on 8/3/10 at 09:11 PM |
or with windows 7
windows key and p
ReMan
posted on 8/3/10 at 09:41 PM |
Fn F4 on my HP
Choose AV on TV if it doess not switch auto
