Seven_Monkey
posted on 30/3/10 at 04:36 PM |
1300 XFlow Pistons
Hi all, just a quick one to see if anyone has or knows of any 1300 xflow pistons around the Northants area?
Hoping to fit to a 1600 rebuild shortly.
Rich
trextr7monkey
posted on 30/3/10 at 05:55 PM |
Got some +40 1300s also a block and most of the bits to rebuild it
prawnabie
posted on 30/3/10 at 08:12 PM |
You need AE 18647 pistons!
Seven_Monkey
posted on 31/3/10 at 11:44 AM |
Thanks Shaun. Will look into these.
Mike, are the +40 able to just drop onto the 1600 rods as there's a stroke differance isn't there between 1300 & 1600?
Rich
trextr7monkey
posted on 31/3/10 at 12:32 PM |
Check with a call to the guys at Burton Power, I'd imagine gudgeon pins are same size, but would need to pull pistons out to check for sure.
atb
Mike
