andkilde
posted on 23/9/10 at 12:44 PM |
Ford 4cyl to T5 Bell
Hello all, bit of a stretch as I don't think they're that common.
Looking for a Ford 4cyl pattern, pinto/zetec/etc to T5 bellhousing.
I'm in Canada but I have a friend in Portsmouth who could ship it across the water for me.
Thanks, Ted
mcerd1
posted on 23/9/10 at 03:28 PM |
well a pinto has the same block as a cossie, so its a cossie rwd bellhousing your after (and release arm I guess)
have you tried any of the cossie breakers over here ?
Dan.
posted on 23/9/10 at 06:10 PM |
Cossie bell housing is what you need, however you will ned to make a slight alteration to starter motor position due to the different flywheel size.
Failing that www.rwdmotorsport.com sell direct fit ones where no modification will be required.
hth
Dan
BigFaceDave
posted on 23/9/10 at 07:01 PM |
I spent quite a long time trying to find one myself and in the end the only way I could find one was to just put 'cosworth breaking' into
ebay and everyime a new add came up I asked the seller a question but virtually everyone wouldn't sell just the bellhousing they wanted to keep
it with the gearbox.
Im having to do the same now as I need a gear shift for my T5 but as before know one wants to sell them seperatley but eventaully I got lucky with the
bell housing but took about 7 months.
andkilde
posted on 23/9/10 at 08:45 PM |
Thanks guys.
Didn't realize there were breakers that specialized in Cossies. Any recommendations for a trustworthy one?
A bell came across here in the FS section a couple of weeks back but it was sold locally.
I've seen the RWDmotorsports one -- it's a little more towards the hicost end of the spectrum, but if it solves a potentially expensive
starter issue that might make it more of a bargain. I've been looking at American Pinto bells, but there's a bit of bodging involved in
making them work as for some inexplicable reason they moved the two top holes up about 3/4".
Cheers, Ted
mcerd1
posted on 23/9/10 at 08:53 PM |
if its for a 2.0 pinto (which I doubt but anyway...) one answer to the starter problem is to get a cossie flywheel, but they have 9 bolts on an odd
pattern so you'll need a crank aswell (and if they arn't a pair you'll need to get them ballanced together)
[Edited on 23/9/2010 by mcerd1]
andkilde
posted on 25/9/10 at 03:04 AM |
ST170 Zetec actually. I think I'll talk to the guys at RWD and figure out the whole package, flywheel, starter, etc. Trying to save a few
pennies might cost more in the end.
Thanks guys, Ted
