oddsaabs
posted on 10/1/11 at 12:05 AM |
zx14 (zzr1400) oil pan install
I installed my new low profile oil pan today. Comes from Two Wheel Werkz here in the US http://www.twowheelwerkz.com/ Very nice piece. The
quality is excellent and it fit without a hitch.
I did a write up for my build log on LocostUSA. You can find it here at the bottom of page 3:
http://www.locostusa.com/forums/viewtopic.php?f=35&t=10160&start=30
Lowered the motor by 3" and hopefully will minimize oiling issues in the corners.
Johneturbo
posted on 10/1/11 at 05:53 PM |
hey Jonathan
Looks good
what are you going to do about runing an oil cooler, (if you are going to that is) maybe a sandwich plate between the oil filter? not sure if they are
off the shelf parts
I have emailed Justin about shipping. i'm just not sure what to do yet. Re oil cooler
oddsaabs
posted on 10/1/11 at 09:01 PM |
I'm planning on running it without an oil cooler to start with and then see how it goes. If there is an issue, an external cooler could be
adapted with a sandwich plate or a fitting to move the filter elsewhere as well. There must be something out there that will fit as the turbo kits
use coolers and remote filters. I've got a nice little SPA oil cooler unit on the shelf that I haven't used in years. It could be
brought into service if required.
Justin is a good guy, a bit querky, but a straight shooter. If he doesn't reply to email then call him. The conversation will be worth the
price of admission.
