ko_racer
posted on 5/7/11 at 08:44 AM |
2006 R1 Engine Package
2006 5VY R1 Engine
Low Mileage
Sump Baffle Plate
155BHP at the wheels when dynod at Daytuner
Complete with:
-Main Loom & USA BO ECU (Immobilisor ins't present on USA ecu so no keys needed for it to run).
-Coil Packs & Loom.
-Throttle Bodies & Loom - Fuel Rail has JIC 6 Connector for easy connection to fuel lines.
-All sensors necessary to run the engine. (Atmos. Press. Sensor, Start Inhibitor Relay etc etc)
-Starter Motor
-Starter Solenoid
-Regulator/Rectifier
-Modified Air Box with built in K&N air filter.
-Exup Valve Servo
-Standard 17t Sprocket
-Thermostat & Housing
Loom is modified to remove all un-necessary switches/sensors and fully labelled up so you can get it running quickly & easily.
AIS System Removed and blanked off.
There are NO Clocks with this kit.
£1450 for the kit. Collection Only from Herts
I also have:
Fueling PowerCommander 3 USB - £155
Ignition PowerCommander 3 - £120
Stainless Exhaust System (4-2-1) - Suitable for mid/rear engined install - £300
adithorp
posted on 5/7/11 at 10:16 AM |
I'll take first dibs on the PC ignition unit.
u2u sent.
[Edited on 5/7/11 by adithorp]
http://jpsc.org.uk/forum/
mikemph
posted on 6/7/11 at 09:21 AM |
2nd dibs on pc3 ignition module
ko_racer
posted on 7/7/11 at 01:12 PM |
Ignition PC3 Sold.
My team mate does have another PC3 Ignition module for the 04-06 R1, if anyone is interested drop me a PM and I'll give you his details.
Toltec
posted on 7/7/11 at 07:11 PM |
Do you have any pictures of the exhaust system, I am going to need one for my R1ot at some point and thinking it might be easier than building one
from scratch. I have an '03 engine but I dare say the setup will not be too different.
u2u sent
ko_racer
posted on 7/7/11 at 09:05 PM |
Ive got some photos of it in the car. I'll post them up when I get to work tomorrow
Regards
Keith
ko_racer
posted on 14/7/11 at 01:22 PM |
Engine Now Sold
