Author: Subject: type 9 to 1800zetec
Mday41
posted on 13/8/11 at 06:55 PM Reply With Quote
type 9 to 1800zetec
hi guys been tinkering all day and was wondering whilel sorting thro my engine stuff what clutch parts im going to need to link the type9 to the zetec 1800 any1 got any clues?
m.day
posted on 13/8/11 at 07:07 PM Reply With Quote
Assuming its a 1.8 flywheel...
Mk1 Mondeo 1.6/1.8 clutch plate and cover, Capri Ct133 release bearing.
Job done!
deltron63
posted on 13/8/11 at 07:09 PM Reply With Quote
I used a 2.0 mondeo clutch in mine with a ct 133 release bearing. No problems so far
big_wasa
posted on 13/8/11 at 07:15 PM Reply With Quote
if its a 1.6-1.8 fly then an early mondeo clutch but you must check it has a 220mm Od 23 spline 1" centre on the clutch plate.
With the above bearing and a spigot bearing.
posted on 13/8/11 at 07:22 PM Reply With Quote
What flywheel??
deltron63
posted on 13/8/11 at 07:34 PM Reply With Quote
1.8
posted on 13/8/11 at 07:59 PM Reply With Quote
1.8
Hmm, didn't think the 2L job fitted the 1.8, and I chucked two away for that very reason.....
big_wasa
posted on 13/8/11 at 08:01 PM Reply With Quote
2.0 should have been the 240mm fly, even the 130 spec 1.8 had the 240mm fly and the mtx75 box.
posted on 13/8/11 at 08:06 PM Reply With Quote
Exactly what I thought....
Mday41
posted on 13/8/11 at 08:32 PM Reply With Quote
thanks for the reply guys so am i getting this right 1.8 fly wich i have the Mondeo cluch etc and the Capri bearing
m.day
deltron63
posted on 13/8/11 at 08:53 PM Reply With Quote
Originally posted by coozer
Originally posted by deltron63[/i
1.8
the 1.8 center plate didn't fit my type9 so i put a 2.0 clutch kit in. it was cheaper to buy the kit and chuck the bearing
big_wasa
posted on 14/8/11 at 07:58 AM Reply With Quote
Most 1.8 engine where fitted with the lower spec IB5 gearbox. This has the smaller first motion shaft. The mondeo with the 1.8 had the mtx75 with the 23 spline 1" first motion shaft. This and the 220mm OD are the imprtant measurments when looking for a clutch. Diesels had the bigger 240mm clutch, same size as the 2.0.
ie this one "should fit" FORD MONDEO 1.8 i 16 V , 4X4 CLUTCH KIT VCK 726 NEW | eBay
gaz05
posted on 14/8/11 at 09:27 AM Reply With Quote
Haven't assembled mine yet but that ^^ is the clutch I bought . I've got a 2.0L with 1.8 Flywheel, CCT133 thrust bearing,1.8 cvh spigot bearing from Ford . Looks like it'll fit together perfectly.
I also threw away a 2.0L clutch form the donor engine because it wouldn't fit the 1.8 Flywheel.
[Edited on 14/8/11 by gaz05]
