whitstella
posted on 22/5/12 at 11:56 AM |
mx5 doner
hi
just brought a mx5 1.8 2000, but i can not get t started. it ran for 30mins last friday and all seemed ok, then went back to it over the weekend and i
could not get it running. ran for about 3 seconds and stopped and tried again and ran for 3 seconds and everytime now just keep turning over. i
checked for a spark yesterday and nothing. i want to put it back on the road so i can run it for 6 months to make sure its ok. any ideas????
cheers steve
bartonp
posted on 22/5/12 at 12:09 PM |
quote: Originally posted by whitstella
hi
cheers steve
It's kebabed.
thefreak
posted on 22/5/12 at 12:12 PM |
Lol
Imobiliser?
adithorp
posted on 22/5/12 at 12:15 PM |
Petrol?
http://jpsc.org.uk/forum/
BigLee
posted on 22/5/12 at 01:28 PM |
quote: Originally posted by adithorp
Petrol?
^^ +1 Tried for hours with mine once. All it needed was fuel.
bonzoronnie
posted on 22/5/12 at 03:04 PM |
Assuming that it has not run out of petrol ?
Another vote for immobilizer.
My Mazda 6 used to do that now & then
Would fire up then promptly stall, if the MX5 has the same system as the 6, if it cuts out 3 times the immobilizer system will lock.
Once the system is locked you can forget about trying to start it.
Sometimes mine would reset itself after a few hours & other times, a battery disconnect would do the trick.
Leave the battery disconnected for 30-60 min's ( I was told it also helps if you turn the ignition on & depress the brake pedal after the
battery has been disconnected )
Is the red key symbol showing on the dash with the ignition on ? ( Should flash when you turn the ignition on & then go out once the signal from
the key has been read )
[Edited on 22/5/12 by bonzoronnie]
