maccmike
| posted on 10/9/12 at 04:43 PM |
Exhaust decibels
I acquired a db meter.
Readings are as follows at 4k rpm (of 10.5k);
no db killer - 104.2
db killer #1 - 100.7
db killer #2 - 100.3
I rev'd it to around 8k and it read 108+
Suggestions on how I can reduce it further in the locost manner please
RickRick
| posted on 10/9/12 at 05:17 PM |
Apparently just putting a bolt in the tail pipe can help small hole in the end of the pipe, install, run nut up it, so that the threaded part just
points across the diameter hoep that makes sense, another option is a ball of wire wool down the pipe before db killers installed, no idea how long
this lasts though
mark chandler
| posted on 10/9/12 at 06:55 PM |
look at intake noise, not exhaust as this can be just as loud !
maccmike
| posted on 10/9/12 at 08:20 PM |
Thanks for that, its the original airbox with an aftermarket 4-1 exhaust so Iv no doubt its the latter.
Chippy
| posted on 10/9/12 at 09:59 PM |
The simple answer is to fit a bigger and better silencer, 6" can with perforated pipe and Acustafil wadding, worked on my V6 reduced the noise a
fair amount. HTH Ray
maccmike
| posted on 10/9/12 at 10:25 PM |
Yeah I can of figured that'd be the proper solution. I dont like spending money though Ray haha.
Got couple of things to try tomorrow then Il go from there
Chippy
| posted on 10/9/12 at 10:31 PM |
One thing about the bigger silencer, over the DB killer, you wont loose all those lovely BHP, and don't be such a tight wad, as somebody on here
has on there page, (anything with tits or wheels is going to cost you money).   Cheers Ray
maccmike
| posted on 10/9/12 at 11:32 PM |
hahahaha
ashg
| posted on 10/9/12 at 11:53 PM |
quote: Originally posted by RickRick
another option is a ball of wire wool down the pipe before db killers installed, no idea how long this lasts though
tried that. makes the car cut out half way to the iva on the motorway. it wasn't fun taking the can off at the side of the road in the january
snow getting the wool out and getting to the test on time.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
bi22le
| posted on 11/9/12 at 06:20 AM |
Acustafil is cheap. If you have a repackable exhaust then just try it, if not then consider making it repackable!!
What exhaust can have you got at the mo? Is it bolt on and exchangable, if so buy a standard bike can from ebay and try that. Or you could add a bend
on the end of the pipe.
Essentially anything you do will choke some power.
Please read my ring story:
maccmike
| posted on 11/9/12 at 08:41 AM |
hi bi22le,
yeah its a bolt on, outlet is 45 degree already.
Im going to whip it off and look inside.
i have a feeling there will be no baffle.
it sounds great, but i want the type of sound you get out the factory and dont mind losing some power.
Minicooper
| posted on 11/9/12 at 09:35 AM |
What about a standard large capacity single rear box like the one fitted to the ZX12r's for example they are very quiet compared to most
exhausts and there are plenty available on the bay
maccmike
| posted on 11/9/12 at 11:12 AM |
hi mini, just tried a road legal can that isnt a straight through like mine, it was only as quiet as mine but with a db killer in, put the killer in
the new can but still above 100db. and much heavier, going to repack mine this afternoon, mod the db killer and see from there.
Minicooper
| posted on 11/9/12 at 12:38 PM |
That's strange as on the road a standard pipe like the ZX12r is whisper quiet compared to the screaming sports bike you get, oh well worth a
shot
Mike have you a build thread for your three wheeler? I'm interested longer term making a three wheeler perhaps front wheel drive if I can get it
to look right, the stance, wheelbase to track ratio on your car looks spot on, would you have those details to hand, it would be interesting to know
them as a starting point.
Did your car have a GSXR1100 engine in it at some point, I remember something similiar for sale years ago?
maccmike
| posted on 11/9/12 at 12:55 PM |
Hi mate, when I bought it, it had an old z1000 engine, I dropped a valve and it wasnt very powreful anyway so dropped the zzr in it last year.
I dont have a diary but could take measurements for you.
Side profile looks good but front on its fugly.
Your welcome to visit if your ever passing.
Minicooper
| posted on 11/9/12 at 01:17 PM |
Thanks Mike,
The wheelbase in particular would be interesting to know
I assume it goes very well with the ZZR1100 motor, I want the performance but with a standard, cheap, available motor, like a ZX9, or early R1, in
order to do that you need to be as light as possible
maccmike
| posted on 11/9/12 at 02:10 PM |
its pissing down now but will measure base and track and let you know.
to say its ballistic is an understatement.
its hard getting the power down with only one contact patch and wheel spin too easy, even at motorway speed.
thats why im not too fussed about losing bhp with the exhaust.
repacked the silencer and modded the db killer, at idle its 10db quieter, at 4k its just over 100 so that'll do.
Minicooper
| posted on 11/9/12 at 06:28 PM |
Thanks Mike,
When it suits yourself, I won't be doing anything other than thinking and drawing at this stage
