Rodeo
| posted on 20/9/12 at 11:57 AM |
Reverse trike Q's
Hi All
Havent been on for a while(not that you missed me!lol)
Having built and MSVA'd my Reliant powered 'normal' wheel config trike.Heres a partial pic....
Ive now started my 2 seater reverse trike build...........pics when Ive got something substantial done!
Cant find this info in the MSVA manual,so presume it is same as for a 4 wheeler car. Do I have to have a collapsible steering column?
Also because I wont have a 'B' post to connect lap and diagonal belts to,can I swap over the belt sets left to right,and have the lap
part coming from the centre instead of the 'B' post? ie drive side..instead of lap coming from right shoulder,have it from the left
shoulder.
Ive tried contacting VOSA test centre but no joy yet.
many thanks in advance for your wisdom!
Rod
[Edited on 20/9/12 by Rodeo]
| posted on 20/9/12 at 12:41 PM |
A trike is a trike irrespective of what end the two parallel wheels are at.
Most likely you'll come under the MSVA heading Tricycle (other than motorcycle).
It's Evolution Baby!
Rodeo
| posted on 20/9/12 at 12:52 PM |
UPDATE!...............Finally got hold of VOSA.Thought I'd share the info........
There isnt a requirement for a collapsible column on trikes...BUT... it it is beneficial to either have a collapsible piece in the col and/or offset
uj's.This would then be seen by the examiner as ok under the const. and use regs.(cars)
Also ..it is ok to swap the belts left to right.
When /if the new laws are taken up which are looming with eu,they will almost certainly tighten up on all this.
smart51
| posted on 21/9/12 at 07:01 PM |
There is a downloadable MSVA manual. Do a google search for it. One thing I know is require but is not in the book is for self centring as per the 4
wheeled SVA test. Mine does this now, after a lot of work to make it!
