Slimy38
posted on 2/7/13 at 11:43 AM |
Very quick grease questions
My poly bushes for the wishbones have just arrived, they look quite good. The top hats for both sides don't meet in the middle which I assume is
correct, would it be a good thing to pack that void with a suitable grease or would that be too much? I'd put the top hats in the wishbone tubes
dry, pack the inside of the bushes with grease, then use the crush tube to push the excess back out.
I seem to remember seeing on here that the crush tube rotates inside the bush, and the bushes stay fixed relative to the wishbone? Is that right?
mookaloid
posted on 2/7/13 at 11:49 AM |
I'd say you have that spot on.
I have even considered fitting grease nipples to the wishbones to fill the void but I am concerned about weakening them.
Mr Whippy
posted on 2/7/13 at 11:50 AM |
They'll squeak if you don't will also feel smoother
AdrianH
posted on 2/7/13 at 11:57 AM |
Just got to get the correct grease in there, is it silicon grease that people use? I know I did.
Adrian
Why do I have to make the tools to finish the job? More time then money.
HowardB
posted on 2/7/13 at 11:58 AM |
many of the cars at the race meet had grease nipples on the bushes,...
![](/galpreviews/20130630_154804_crop.jpg) ![Description](/gallery/20130630_154804_crop.jpg) Description
[Edited on 2/7/13 by HowardB]
Howard
posted on 2/7/13 at 12:34 PM |
Make sure that the crush tubes aren't too short , do a dummy build of the bush assembly and nip the crush tube in a vice then check that the
wishbone can rotate freely around the crush tube , if it doesn't then it won't matter how much grease you use , it will still bind. The
crush tube does not rotate ,it should be clamped solidly between the mounting bracket, the bush and wishbone rotate around the crush tube
Slimy38
posted on 2/7/13 at 01:02 PM |
Thanks for the tip. I've already had a go with the crush tube and the brackets. The brackets I have were ever so slightly open, so I wanted to
see what would happen when they were bolted up against the crush tubes. They closed up a little as I tightened the bolt, so I'm happy the tubes
and the brackets both meet the requirements. Now I just need to ensure the wishbone tubes are similarly in spec.
big-vee-twin
posted on 2/7/13 at 03:09 PM |
You need to use a moly based grease i.e. a grease that is not a petroleum product to prevent it eating the poly bush.
http://www.triangleltd.com
PhillipM
posted on 2/7/13 at 03:14 PM |
'moly' grease is actually lithium based in most cases, the moly is just an additive, so 95% of the time it is petroleum thickened with
lithium and fortified with moly for high loads.
Having said that, most poly bush compounds are quite tolerant of petroleum greases anyway.
[Edited on 2/7/13 by PhillipM]
Slimy38
posted on 2/7/13 at 03:29 PM |
It's a tub of lithium grease that I was planning to use, it's served me well when I fitted poly bushes to my tin top.
PhillipM
posted on 2/7/13 at 03:43 PM |
Can't say I've had any issues with lithium on most polybushes - I usually use Hi-Mol 20 - but the 'failsafe' option is a
silicone based grease.
