austin man
| posted on 13/8/13 at 10:54 PM |
steering bush
I am considering fiting a bearing in place of the nylon bush on the siera column, this bearing will hopefully go ove the triangular section of the
steering shaft and mount to the bulkhead. Has anyone done this if so what side bush do i need ie the internal diameter
james h
| posted on 14/8/13 at 12:33 AM |
Keep the sierra standard bush - this will fit inside the bearing. I can't quite remember the bearing but will check...
James
ETA:
THIS is the fitment of the bearing.
HERE is the
bearing you need!
[Edited on 14/8/13 by james h]
Daddylonglegs
| posted on 14/8/13 at 07:03 AM |
Beat me to it!
40inches
| posted on 14/8/13 at 08:52 AM |
This one
may be better, the Sierra bush is 1" diameter.
stevegough
| posted on 14/8/13 at 09:35 AM |
You need a pic....there you go. I think mine was the one 100 inches has linked to.
[Edited on 14/8/13 by stevegough]
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
Sloan85
| posted on 14/8/13 at 09:39 AM |
I used this one on my sierra column. £6.56 delivered.
eBay bearing link
[Edited on 14/8/13 by Sloan85]
http://mkindygsxr.blogspot.co.uk
jps
| posted on 14/8/13 at 10:09 AM |
Here's how I did it - I think I got mine from Bolton Bearings on eBay - the plastic insert from the Sierra column fitted straight in (apparently
some people have had to sand it lightly to get it to fit). As the bearing can be angled you don't even need to weld an angled plate to the
bulkhead - just drill two holes to mount it!
http://meandthekitcar.wordpress.com/2013/07/14/sbpfl205-slfl25/
bi22le
| posted on 14/8/13 at 04:32 PM |
I never knew these solutions exiated! I was being mocked at the weekend for having play in my steering wheel. I just said it helped take thw bumpyness
out of the track!!
Added to my purchase list. Thanks.
Please read my ring story:
