dan8400
posted on 30/10/17 at 08:44 AM |
Custom steering rack extensions
As title.
I am after some custom steering rack extensions for my trike build. I have a punto steering rack which is m12 x 1.5 threads. I need to connect these
to Sierra track rod ends.
I will double check the thread sizes and length I need.
I just need to know where to go to get these made and approximate costs. Unless I can pay anyone on here can do them
Dan
Hey - That's Journey!!!
posted on 30/10/17 at 11:48 AM |
I can't make them for you, but whilst building my MK Indy I made friends with a local engineering firm. They proved very useful as a source of
materials and for getting some bits made - e.g. seat mounts welded up. If you can find someone similar and give them the track rod and rod ends they
may be able to make what you need.
russbost
posted on 30/10/17 at 11:54 AM |
M12 x 1.5 is the same as the Cinquecento rack I use for the Furore, I have extensions 170mm long (75mm internal thread, 50mm on the male end), which
have M12 x 1.25 thread on the outer end for the Toyota TRE's , no idea whether that matches up with Sierra thread?
dan8400
posted on 30/10/17 at 11:58 AM |
The Sierra thread is m14 x 2
Russ, I don't suppose you know the size of the taper on the Toyota TRE?
Good suggestion nick. I will have a look into local firms
Dan
russbost
posted on 30/10/17 at 12:02 PM |
We have tapers made to fit the Toyota TRE's for our hub adapters, they are 20mm thick, & the taper goes from 15.5mm down 12.5mm, I believe
that is a 4.8 deg taper each side, total inclusive taper of 9.6 deg
dan8400
posted on 30/10/17 at 12:10 PM |
I know it's a long shot, but do you know if that is compatible with the Sierra TRE?
russbost
posted on 30/10/17 at 12:13 PM |
Sorry, but no idea as I don't use Sierra stuff, I'm sure several peeps on here must know, worth asking a separate Q in case others
aren't following this thread? Might be close enough that a tapered reamer would sort it for you?
MattD
posted on 30/10/17 at 01:19 PM |
Source - http://www.super7thheaven.co.uk/blog/haynes-roadster-lower-front-arm/
Not sure I like the wishbone design on first pass... too many moveable fasteners to flex for my liking.
But it gives the taper info you need.... & the drawing linky links back to LCB !!
http://locostbuilders.co.uk/upload/a1084019-sierra%20upright.jpg
According to Ford and the drawing below, a standard track rod end taper is 7° 9′ 7″
7° 9′ 7″ = 7.151944°
[Edited on 30/10/17 by MattD]
dan8400
posted on 30/10/17 at 06:45 PM |
Thanks for the info. Just to confirm, the TRE taper is: 7.151944 degrees?
Dan
MattD
posted on 30/10/17 at 07:16 PM |
Yes, it says 7.1 degrees.
dan8400
posted on 30/10/17 at 07:20 PM |
Thank you
